Zooming to match a raster scale
Nick Dabner
dabner at OPTUSNET.COM.AU
Mon Apr 25 01:58:17 EDT 2005
Ed,
Thanks for the quick response. Followed your workings and got what is a
near perfect match for another scale. In doing so, I can see how is
resolution is used, which was some explanation I hadn't found detailed
elsewhere. Kept it at 72 dpi.
Yes, preview is slow, but the results are nice. Gdalwarp changes
projections if I am not mistaken. Do you mean gdal_translate to create
the raster pyramids? Will have to give this a try later today as my
rasters do vary, especially with inner-city areas. It loooks like I
would supply the output size in pixels (x,y) to get the the desired
scale.
Definately info like this is helpful for us non-geo-versed. Need this
kind of info in the --verbose docs!
Cheers,
Nick
On 25/04/2005, at 11:55 AM, Ed McNierney wrote:
> Nick -
> I'm not sure what your "unit" is supposed to mean, but I can describe
> the process for taking the pixel size and finding the right
> MINSCALE/MAXSCALE values.
> The MINSCALE and MAXSCALE values are the denominators of scale ratios,
> like 1:10,000 scale. MINSCALE 10000 means "a minimum scale of
> 1:10,000", where one meter on the map equals 10,000 meters on the
> ground. The problem becomes, "what's one meter on the map"?
> The RESOLUTION statement answers that question. The default value is
> 72, meaning that 72 pixels in a MapServer output image are presumed to
> occupy one inch on the screen. This is actually unlikely to be an
> accurate value unless you're running a 20-year-old Macintosh, but it
> often doesn't matter - it's mostly used for internal calculations.
> So, if 72 pixels are presumed to cover one inch on the screen, and
> your image has a source resolution of 1.26956817 meters per pixel,
> then one inch on the screen will show 72 * 1.26956817 meters or
> 91.40890824 meters of image. Since 91.40890824 meters equals
> 3598.7687 inches, this means one inch on the screen shows 3598.7687
> inches on the ground - a scale ratio of 1:3598.7687
> If you displayed that image at the "scale" of 3598.7687 you should get
> a pixel-for-pixel replica of your source image. If you use a
> different RESOLUTION statement, you need to adjust accordingly.
> For calculating the IMGEXT values, you simply need to make the X
> extent and Y extent equal the number of (X or Y) pixels in the image
> times 1.26956817.
> Yes, there are better-quality ways of resampling images, but - as you
> saw in Preview - they're slow. MapServer doesn't use them, but you
> can use various tools (including gdalwarp, from the GDAL distribution)
> to resample images offline and create "pyramids" of varying
> resolutions. This will improve the display quality of your images
> while keeping the performance fast - at the expense of extra disk
> space and preprocessing work.
> - Ed
> Ed McNierney
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050425/f99ae31a/attachment.bin
