Questions on projections, reference systems, map extents,
scales
Vortex
vortex25 at GMX.DE
Mon Apr 25 03:54:11 EDT 2005
Hello Ed!
On Sun, 24 Apr 2005 22:08:57 -0400
Ed McNierney <ed at TOPOZONE.COM> wrote:
> "Vortex" is a good choice - you're certainly spinning around rapidly!
> ask questions in the most appropriate places. For example, there is a
> separate mailing list for PROJ and that's the best place to ask
> questions about it.
I'm afraid you are right. Your answers helped me a lot anyway and
i try to write some short comments.
> Yes, the "geographic" coordinate system refers to longitude/latitude
> coordinates. Longitude and latitude are NOT "always the same" and must
> be expressed relative to a datum; 30 degrees North, 90 degrees West is
> NOT the same location in the NAD27 datum as it is in NAD83. WGS83 and
Ok! So i suppose this comes from different equator/meridian definitions
inside the datums or something like that? (But you don't need to answer
this because i will follow your advice :-)
> NAD83 are datums - they are not coordinate systems. Cartographic
> coordinate systems are based on datums.
Ok! I think i got this.
> If you have "pure" (most people would say "unprojected")
> longitude/latitude data you still need to know what datum is used.
Ok, i understand this now.
> If the output and input projections are identical there is no
> reprojection done. Yes, this is faster, but vector reprojection is VERY
> fast and not worth worrying about (at least, not now).
Ok!
> You will have MUCH better luck getting answers if you limit your
> postings to one or a few related questions. Long laundry lists of
> questions tend to make readers (a) feel they don't have time to answer
> all those questions and/or (b) don't know how to answer ALL of them, so
> they might as well not answer ANY of them.
Ok, i will consider this for my next posting.
Thank you for having the patience!
Klaus
" WWW: http://db0fhn.efi.fh-nuernberg.de/~dg1nav?vo
" LOCAL: klaus at castle.kwsnet
" EMAIL: vortex25 at gmx.de
" AX.25: dg1nav at db0fhn.#bay.deu.eu
