HPGN Datum? (fwd)
Dean C. Mikkelsen
dcmikkelsen at SHAW.CA
Tue Apr 26 03:57:45 EDT 2005
Hi Didrik,
In the epsg file, for NTF II, I get the following:
# NTF (Paris) / France II
# Unable to translate coordinate system into PROJ.4 format.
I could not find your code 27572.
Let me suggest a work-around. It may not be popular, but it should solve
the problem for you.
In the epsg file, add the following line of code:
<27572> +proj=lcc +lat_0=18.000000000 +lon_0=-77.000000000 +k=0.99987742
+x_0=600000 +y_0=2200000 +ellps=clrk66 +towgs84=-168,-60,320,0,0,0,0
+units=m no_defs <>
This should resolve the problem.
Let me know what happens.
Kind regards,
Dean
Dean C. Mikkelsen,B.Sc.,P.Eng.
Principal Consultant
Terra ETL Ltd. - Consultants on GIS & Geodesy
Vancouver, B.C., Canada
Phone: 604-929-8630
E-mail: dcmikkelsen at shaw.ca
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Didrik Pinte
Sent: April 26, 2005 12:06 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] HPGN Datum? (fwd)
Le mardi 26 avril 2005 à 08:22 +0200, Didrik Pinte a écrit :
> Le lundi 25 avril 2005 à 23:00 -0400, Frank Warmerdam a écrit :
> > In any event, if you error is on the order of 100m then the
> > problem is likely not the false northing being off by 350000
> > (meters or feet). That level of error is mostly likely related to
> > the datum shifting not being applied or possibly a mixup between
> > different kinds of feet. I am doubtful it is related to HPGN since
> > my understanding is that the difference between NAD83 and HPGN
> > is small (less than 5 meters say), though I am not too sure about
that
> > part.
> I did not follow all the thread but it seems I have the same problem
> here.
> I have a layer with rasters in epsg:27572 (France NTF II) and some GPS
> points in WGS84. The error in reprojection of the points to epsg:27572
> is less than 100 meters.
> I really don't know how to solve this but there must be a solution.
> Didrik
Here is the related .map file (without symbol definition and all the
rasters)
MAP
IMAGETYPE PNG24
DEBUG ON
EXTENT 347839 1.7954e+06 402109 1.83667e+06
IMAGECOLOR 255 255 255
SIZE 500 300
STATUS ON
SHAPEPATH "/var/www/mapserver/maps"
RESOLUTION 81.28
PROJECTION
"init=epsg:27572"
END
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
WEB
LOG "/tmp/mapserver.log"
IMAGEPATH "/var/www/mapserver/tmp/"
IMAGEURL "/tmp/"
#Template file used for the base map
TEMPLATE "templates/followap.html"
#Header of the query window
HEADER "templates/header.html"
#Template used if nothing is found in the query
EMPTY "../mapserver/templates/empty.html"
END
LAYER
NAME "europe"
DATA "shape/europe3.shp"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
PROJECTION
"init=epsg:27572"
END
END
LAYER
NAME "Regions"
DATA "shape/franceNTF_France2.shp"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
PROJECTION
"init=epsg:27572"
END
END
LAYER
NAME "moved"
CONNECTION "user=postgres password=***** dbname=test
host=localhost port=5432"
CONNECTIONTYPE postgis
DATA "the_geom from gpsdata"
STATUS ON
TYPE POINT
DEBUG ON
TOLERANCE 5
TEMPLATE "templates/filling.html"
CLASS
NAME "Objet récemment déplacées"
EXPRESSION ([moved] >= 1)
COLOR 255 0 0
OUTLINECOLOR 255 0 0
SIZE 10
SYMBOL "circle"
END
CLASS
NAME "Objet non déplacées"
EXPRESSION ([moved] < 1)
COLOR 0 255 0
OUTLINECOLOR 0 255 0
SIZE 10
SYMBOL "circle"
END
PROJECTION
"init=epsg:4326"
END
END
LAYER
