Shift of the map if the equirectangular projection is used
MAPSERVER-USERS Cave
caveeagle at POCHTAMT.RU
Tue Apr 26 11:47:32 EDT 2005
If I draw the map in the equirectangular projection with Perl, the map
shifts for about 10 minutes to the north.
If I set the projection in a cgi-script, everything is displayed
correctly. To draw the same map with the Perl API, I use this
function:
$map->setProjection("proj=eqc,lat_ts=63.495,lon_0=46.165");
Then I calculate extent with the command "proj":
proj +proj=eqc +lat_ts=63.495 +lon_0=46.165 <<EOF
> 40.5 60.41
> 51.83 66.58
And get:
-281432.71 6724810.44
281432.71 7411651.70
Set extent in my program:
$map->setExtent('-281432.71','6724810.44','281432.71','7411651.70');
In the result, I get the map shifted exactly to the north, with the
extent of latitude about from 60,6 to 66,8 instead of 60,41 and 66,58.
The extent of longitude is correct.
What is the cause of this error? Can I set the projection in Perl,
without setting the extent?
Hope for Your help. Best regards,
Efremov Victor, Space Monitoring Information Support laboratory IKI RAN, Moscow, Russia.
mailto:caveeagle at pochtamt.ru
