dynamically change reference map image
    Dylan Beaudette
    dylan at IICI.NO-IP.ORG
    Tue Apr 26 11:43:10 PDT 2005
Edmar,
thanks for the tip...
however, this does not seem to change the reference image...
any ideas on what might be preventing this from working?
i am using the DHTML interface developed my UMN.
thanks!
On Tuesday 26 April 2005 04:13 am, Edmar Moretti wrote:
> You can use the url to set the reference image:
> &map_reference_image=path_to_image
> On 22 Apr 2005 at 14:42, Dylan Beaudette wrote:
> > Hi everyone
> > is it possible to dynamically set the properties of the REFERENCE object
> > in a map file?
> > for example,
> > i would like to adjust my map file based on URL arguments:
> > REFERENCE
> >                 STATUS ON
> >                 IMAGE "%file_name%.png"
> > however, this does not work. if i manually enter the file name of the
> > reference image into the map file everything works ok...
> > any ideas on this one?
> > Dylan Beaudette
> > Soils and Biogeochemistry Graduate Group
> > University of California at Davis
> > 530.754.7341
> Edmar Moretti
> Geógrafo
> Ministério do Meio Ambiente
> Coordenação Geral de Tecnologia da Informação
> fone: (61) - 4009-1233
> http://mapas.mma.gov.br/mapas
> masn: edmarmoretti at hotmail.com
Dylan Beaudette
530.754.7341
More information about the MapServer-users
