Relationship between Unit dd and MAX/MINSCALE
Ed McNierney
ed at TOPOZONE.COM
Wed Apr 27 13:27:13 EDT 2005
Paul -
Thanks; I don't think it's worth attempting to fix something that's
unfixable. As one moves further from the equator, not only does the
size of a degree of longitude change, but any actual measurement becomes
more and more dependent on the angle of the line measured, since the
difference between the size of a degree of latitude and a degree of
longitude grows.
We've had map projections for about two millenia or so, and there's a
reason for that <g>.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Paul Spencer
Sent: Wednesday, April 27, 2005 12:53 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Relationship between Unit dd and
MAX/MINSCALE
I believe that MapServer uses an approximation based on the length of a
degree at the equator when using a geographic projection, which means
that the latitude will not affect your scalebar and it will be
increasing inaccurate the further south/north you get.
I believe some tests were done by Daniel to use a great circle
calculation to get a more accurate number based on current latitude but
the results were inconclusive as to whether it was actually more or less
accurate this way.
Paul
Ed McNierney wrote:
> Tim -
> I do not know how MapServer calculates a scalebar in linear units
> (feet, meters, miles, etc.) from data that's in ellipsoidal
> coordinates. I have no idea whether it's doing the right thing for
> your particular case.
> You might be able to easily test it by viewing data at different
> latitudes - if the scalebar doesn't change, it's not working.
> - Ed
> Ed McNierney
> ed at topozone.com
> On Behalf Of Tim
> Sent: Wednesday, April 27, 2005 11:35 AM
> MAX/MINSCALE
> On Wed, Apr 27, 2005 at 09:02:56AM -0400, Ed McNierney wrote:
>>If your units are DDs, you cannot express them in miles - it's
>>meaningless, since the distance between any two points on such a map
>>(in
>>miles) depends on the latitude of the map and the angle of the
>>distance being measured.
> Hmmm, does that mean my scalebar is meaningless? Note that in this
> case, I am referring to latitude only so technically I am only talking
> about the horizontal distance and the distortion should be minimal.
>>This is one of the reasons using "geographic" output projections for
>>maps is, IMHO, a very poor practice that seems to be infesting the Web
>>mapping world.
> Should I be using an equidistance projection then? That's normally
> OK except I am overlaying some information outside of MapServer that's
> unprojected.
> Thanks,
> Tim
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
