mapserv segfaults trying to get the query results of a native
oracle spatial data source
Nicol Hermann
mapserver at GEOWORLD.DE
Thu Apr 28 10:04:13 EDT 2005
Dear list,
I want to use the query function of the native Oracle Spatial support
(INPUT=ORACLESPATIAL) from mapserver 4.4.2.
Displaying the image is no problem but when try to get the query results
mapserver crashes with a segmentation fault.
Here is what i try to do:
for($j = 0;$j < $Layer->getNumResults(); $j++) {
$oRes = $Layer->getResult($j);
$shpobj = $Layer->getShape($oRes->tileindex,$oRes->shapeindex); // <-
Line which causes the Segmentation fault
$shpobj->free();
Is this a bug or do i have to change something?
My system is:
Debian sarge, mapserver 4.4.2 (php Mapscript), oracle 10g
Attached you find the output of gdb.
Any help are welcome
Nicol
gdb php
GNU gdb 6.3-debian
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "i386-linux"...Using host libthread_db
library "/lib/libthread_db.so.1".
(gdb) run nativ_oraclequelle_query.php
Starting program: /usr/local/bin/php nativ_oraclequelle_query.php
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 8826)]
[Thu Apr 28 15:43:33 2005].517414 msOracleSpatialLayerOpen called with:
GEOMETRIE from FLURST USING UNIQUE ID SRID 82027
[Thu Apr 28 15:43:33 2005].676912 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
[Thu Apr 28 15:43:33 2005].676970
msConnPoolRegister(gw,user/passwd at BOX.os,0x82c1b20)
[Thu Apr 28 15:43:33 2005].682921 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:33 2005].683009 msOracleSpatialLayerWhichShapes was
called.
[Thu Apr 28 15:43:56 2005].723744 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:56 2005].723961 msOracleSpatialLayerClose was called.
Layer connection: user/passwd at BOX.os
[Thu Apr 28 15:43:56 2005].724036 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Thu Apr 28 15:43:56 2005].724211 msOracleSpatialLayerClose. Cleaning
Oracle handlers.
[Thu Apr 28 15:43:56 2005].724310
msConnPoolRelease(gw,user/passwd at BOX.os,0x82c1b20)
[Thu Apr 28 15:43:56 2005].724388
msConnPoolClose(user/passwd at BOX.os,0x82c1b20)
[Thu Apr 28 15:43:56 2005].733201 msDrawMap(): Layer 0 (gw), 23.216s
[Thu Apr 28 15:43:56 2005].826353 msDrawMap(): Drawing Label Cache,
0.000s
[Thu Apr 28 15:43:56 2005].826471 msDrawMap() total time: 23.310s
Content-type: text/html
X-Powered-By: PHP/4.3.8
<IMG SRC=/~nicol/mapserver/tmp/111469581388261.png>
<p>Anzahl der Layer: 1 - Anzahl der Klassen dieses Layers: 1[Thu Apr 28
15:43:56 2005].904965 msOracleSpatialLayerOpen called with: GEOMETRIE
[Thu Apr 28 15:43:57 2005].34902 msOracleSpatialLayerOpen. Shared
[Thu Apr 28 15:43:57 2005].35066
msConnPoolRegister(gw,user/passwd at BOX.os,0x8312cd8)
[Thu Apr 28 15:43:57 2005].40125 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:57 2005].74273 msOracleSpatialLayerGetItems was
called.
[Thu Apr 28 15:43:57 2005].164273 msOracleSpatialLayerInitItemInfo was
called.
[Thu Apr 28 15:43:57 2005].164347 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:57 2005].164362 msOracleSpatialLayerGetItems was
called.
[Thu Apr 28 15:43:57 2005].244219 msOracleSpatialLayerInitItemInfo was
called.
x: 3405582.21859 - y: 5521435.53345 [Thu Apr 28 15:43:57 2005].244493
msOracleSpatialLayerOpen called with: GEOMETRIE from FLURST USING UNIQUE
ID SRID 82027
[Thu Apr 28 15:43:57 2005].244511 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:57 2005].244527 msOracleSpatialLayerWhichShapes was
called.
[Thu Apr 28 15:43:57 2005].418013 msOracleSpatialLayerFreeItemInfo was
called.
[Thu Apr 28 15:43:57 2005].418058 msOracleSpatialLayerClose was called.
Layer connection: gdv/gdv at BOX.GDV
[Thu Apr 28 15:43:57 2005].418070 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Thu Apr 28 15:43:57 2005].418112 msOracleSpatialLayerClose. Cleaning
Oracle handlers.
[Thu Apr 28 15:43:57 2005].418124
msConnPoolRelease(gw,user/passwd at BOX.os,0x8312cd8)
[Thu Apr 28 15:43:57 2005].418140
msConnPoolClose(user/passwd at BOX.os,0x8312cd8)
Anzahl: 5 <br>0. Ergebnis stdClass Object
[shapeindex] => 0
[tileindex] => -1
[classindex] => 0
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 8826)]
msOracleSpatialLayerGetShape (layer=0x8284b50, shape=0x830c430,
record=0) at maporaclespatial.c:1258
1258 msOracleSpatialHandler *hand = (msOracleSpatialHandler
*)layerinfo->orahandlers;
(gdb)
