Find nearest line ...
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Apr 28 19:04:23 EDT 2005
Paul: You should be able to retrieve the line by stepping through the search layer search results and then doing a getShape based on the results. Depending on the language I'm sure there are a number of examples readily available.
Steve
>>> Paul james <pauljame at GMAIL.COM> 04/28/05 12:19 PM >>>
I´m using PostGis/mapscript, and I found the nearest line of a point
with queryByPoint... And I can print this line with drawQuery... But I
need to identify this line in postgre/POSTGIS... Is it posible?
thank you
Paul
