convert metres to decimal deg
Ed McNierney
ed at TOPOZONE.COM
Thu Apr 28 21:53:41 EDT 2005
Raghu -
You can't. The relationship is non-linear, and depends on the location
of the point. MapServer can easily reproject your data layers
dynamically for you so you can combine those data sets in a single map.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Shantha, Raghavendra Vasanth
Sent: Thursday, April 28, 2005 1:02 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] convert metres to decimal deg
I have a few raster datasets in Geographic coordinate system
(extent units in decimal deg), and a few datasets in Proj Coordinate
system (extent units in meters)
Are there any resources/formulae to convert meters to corresponding
decimal degrees, without changing the projection type?
Thanks,
Raghu
