EPSG
Piero Cavalieri
piero.cavalieri at HEIDI.IT
Mon Aug 1 07:12:59 EDT 2005
I try:
# MGI / Austria Lambert
<31287> +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5 +lon_0=13.33333333333333
+x_0=400000 +y_0=400000 +ellps=bessel +units=m +no_defs no_defs <>
Epsg codes can be found in the epsg file inside the Proj\nad installation
dir, for example
Cheers
P.
Leopold Schefcik (MULTIMEDIAPLAN.AT) wrote:
>hi list,
>I have data in this projection:
>Map_Projection:
> Map_Projection_Name: Lambert Conformal Conic
> Lambert_Conformal_Conic:
> Standard_Parallel: 46.000000
> Standard_Parallel: 49.000000
> Longitude_of_Central_Meridian: 13.333333
> Latitude_of_Projection_Origin: 47.500000
> False_Easting: 400000.000000
> False_Northing: 400000.000000
> Planar_Coordinate_Information:
> Planar_Coordinate_Encoding_Method: coordinate pair
> Coordinate_Representation:
> Abscissa_Resolution: 0.000512
> Ordinate_Resolution: 0.000512
> Planar_Distance_Units: meters
> Geodetic_Model:
> Horizontal_Datum_Name: D_MGI
> Ellipsoid_Name: Bessel_1841
> Semi-major_Axis: 6377397.155000
> Denominator_of_Flattening_Ratio: 299.152813
>Question 1: Does anybody know what EPSG this is?
>Question 2: How can I get the right EPSG?
>greatings, Leopold
