problem with tiled layer
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Aug 2 16:51:05 EDT 2005
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com> wrote:
> I'm using Mapinfo files for vector data, some of the layers are
> county-based. I created tiled index layers for these county-based layers
> (my demo consists of four counties in North Carolina) using the ogrtindex
> utility. When the map straddles the border between two counties, the tiled
> layers do not appear in one of the counties (the roads, etc. stop at the
> county border). Panning either direction so that the map no longer
> straddles the border makes the missing layers reappear. I assume this is a
> bug in GDAL/OGR or mapserver (CGI version 4.4.1). Has anybody else seen
> this problem? Is there a workaround, or do I need to rethink my use of
> tiled layers? The application will need to cover the entire U.S., so
> effective indexing of the data is a requirement.
David,
I haven't seen a problem like this and find it a bit hard to imagine
how it could be occuring unless there are complicating factors
not clear from your email.
If you can reproduce in a way I can replicate easily with 4.6,
then I would be willing to dig into it and try to fix it. I'm not too
keen on looking into 4.4 issues though.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
