Installation
prashant n
my_massoo at LYCOS.COM
Wed Aug 3 04:21:19 EDT 2005
thanks to all of mapserver guys and those who are supporting the map serving
regards
shann
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Installation
Date: Fri, 29 Jul 2005 11:33:01 +0200
> prashant n wrote:
> > hi list,
> > is it possible to publish this document in either pdf / ps / open
> > office format so that everyone can have a look at this and follow
> > the instructions.
> > Mr.Till Adams, can you publish this as it would be great help to
> > mapserver newbees like me, who often run into installation
> > problems
> > Thanks & Regards
> > Shann
> > From: "Till Adams" <adams at TERRESTRIS.DE>
> > Date: Wed, 27 Jul 2005 16:24:57 +0200
> >> Geraint Lee wrote:
> >>> Till Adams wrote:
> >>>> Geraint Lee wrote:
> >>>>> Hey all,
> >>>>> I've been trying to install mapserver for several days now, coming
> >>>>> accross a number of installation problems (with other programs like gd,
> >>>>> jpeg-2b...) which i've overcome... now i'm stuck on mapserver.
> >>>>> gd, jpeg, freetype2, libiconv and libpng are all installed on the server
> >>>>> (FreeBSD 4.11)... anyway, here's the output from:
> >>>>> ./configure --with-png=/usr/local --with-jpeg=/usr/local
> >>>>> --with-freetype=/usr/local --without-xpm --with-libiconv=/usr/local
> >>>>> --with-gd=/usr/local
> >>>>> configure: checking where FreeType 2.x is installed...
> >>>>> using libfreetype from -L/usr/local/lib -Wl,--rpath
> >>>>> -Wl,/usr/local/lib -lfreetype -lz
> >>>>> checking for FT_Init_FreeType in -lfreetype... no
> >>>>> using libfreetype -L/usr/local/lib -Wl,--rpath
> >>>>> -Wl,/usr/local/lib -lfreetype -lz from system libs.
> >>>>> configure: checking where Zlib is installed...
> >>>>> checking for zlibVersion in -lz... yes
> >>>>> using libz from system libs.
> >>>>> configure: checking where PNG is installed...
> >>>>> using libpng from -L/usr/local/lib64 -lpng
> >>>>> configure: checking whether we should include JPEG support...
> >>>>> using libjpeg from system -L/usr/local/lib64 -ljpeg
> >>>>> configure: checking where libiconv is installed...
> >>>>> checking for iconv_open in -lc... no
> >>>>> checking for libiconv_open in -liconv... yes
> >>>>> using libiconv from -L/usr/local/lib64 -liconv
> >>>>> libiconv found. Enabling internationalization (-DUSE_ICONV)
> >>>>> configure: checking for GD 2.0.12 or higher...
> >>>>> checking for gdImageSetAntiAliased in -lgd... no
> >>>>> configure: checking whether GD needs libiconv...
> >>>>> configure: error: Could not find gd.h or libgd.a/libgd.so in
> >>>>> /usr/local. Make sure GD 2.0.12 or higher is compiled before calling
> >>>>> configure. You may also get this error if you didn't specify the
> >>>>> appropriate location for one of GD's dependencies (freetype, libpng,
> >>>>> libjpeg or libiconv).
> >>>>> -- all of those files exist in /usr/local/lib and /local -
> >>>>> does anyone have
> >>>>> any suggestions at all as to what the problem may be.
> >>>>> Thanks
> >>>>> Geraint
> >>>> Geraint,
> >>>> which OS (Debian Linux, Suse, edHat, etc.) do you use?
> >>>> We have several step-to-step descriptions (sorry for not
> >>>> making them open to everybody till now) for Win, Suse 9.x,
> >>>> Debian Woody and Sarge, Mandrake, RedHat and FreeBSD. I may
> >>>> send you the appropriate for you.
> >>>> Fiorst of all - the easiest may be just to try a
> >>>> # /sbin/ldconfig /usr/local/lib -v
> >>>> and
> >>>> # /sbin/ldconfig /local -v
> >>>> to make the libs known to your system. Also add these pathes
> >>>> to the file /etc/ld.so.config, so you don't have to do this
> >>>> every time you reboot.
> >>>> Greetings from Bonn, Till
> >>> Hi,
> >>> i'm running FreeBSD-4.11.
> >>> i've tried /sbin/ldconfig -v /usr/local/lib with no luck
> >>> i would appreciate it if you could send the installation
> >>> instructions for freebsd.
> >>> Thanks
> >>> Geraint
> >> Geraint,
> >> it's OpenOffice format - hope you may read this - if there are
> >> any comments, please add and send it back
> >> Send it in a minute direct, so I don't bory this list with
> >> attaschments - have fun! Till
> >> -- Mit freundlichen Grüssen aus Bonn,
> >> Till Adams
> >> * released: AmeiN! ArcMap-Export-2-UMN *
> >> * LiveLinux 'WebGIS on CD' *
> >> * http://www.terrestris.de *
> >> Dipl. Geogr. Till Adams
> >> terrestris, H. Paulsen& T. Adams GbR
> >> Siemensstr. 8 * 53121 Bonn
> >> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> >> info at terrestris.de * http://www.terrestris.de
> Dear Prashant,
> we will put these documents on the NEW mapserver website as
> Howto's. I think they will be there in the next two weeks.
> I send them to you personally now.
> Cheers, Till
> Till Adams
NEW! Lycos Dating Search. The only place to search multiple dating sites at once.
http://datingsearch.lycos.com
