Not producing all layers?
Owens, Ryan J NWD02 CONTRACTOR
Ryan.J.Owens at NWO02.USACE.ARMY.MIL
Tue Aug 9 07:58:35 EDT 2005
Hello List,
A couple of weeks ago I wrote about a problem that I was having with Map
Server not being able to produce a PNG image. I changed the format to JPEG,
because PNG was not a format that Map Server was configured to produce. I am
still having problems. I am able to produce the first layer entitled
"oma24kqd.shp," but nothing after that pops up. The map file is actually
calling another map file called "drg24.map". The DGR24.map file is actually
identical to the map file you see below. Actually, the only layer I really
care about is the layer with the oahe.shp file listed as the data.
Would someone take a brief moment to scan the code to see if there is any
obvious errors that maybe I just don't see?
I would appreciate someone's assistant very much. Thanks!
Ryan
# Start of map file
NAME EDOQ
STATUS ON
SIZE 600 600
# Extents from lower left to upper right (minx miny maxx maxy)
# EXTENT -545712 26685 1428199 1537062
EXTENT -110 36 -90 46
#UNITS meters
UNITS dd
#SHAPEPATH "data"
IMAGECOLOR 100 100 200
IMAGETYPE png
#IMAGEQUALITY 96
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
FORMATOPTION "QUALITY=95"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
PROJECTION
# MRR Albers projection
#"proj=aea"
#"Lat_1=40.3861111"
#"lat_2=47.272222"
#"lat_0=37.0"
#"lon_0=-105.685556"
#"x_0=0.0"
#"y_0=0.0"
#"ellps=clrk66"
#"datum=NAD27"
#"units=m"
"init=epsg:4326"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE demo.html
# MINSCALE 1000
# MAXSCALE 40000
IMAGEPATH "/u01/app/oracle/product/9.2.0/Apache/Apache/htdocs/tmp/"
IMAGEURL "/tmp/"
METADATA
WMS_TITLE "NWD-PDM DRG"
WMS_ABSTRACT "Water Management DRG of Omaha in TIF Format"
WMS_ACCESSCONSTRAINTS "For US Army Corps of Engineers Use Only."
WMS_ONLINERESOURCE
"http://[domain]/cgi-bin/mapserv?map=../htdocs/mapserver/drg/drg24.map&"
WMS_SRS "EPSG:4326 AUTO:42003 "
END
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
### DRG 24,000 ###
LAYER # DRG data
NAME drg24
TYPE raster
TILEINDEX "oma24kqd.shp"
MAXSCALE 40000
STATUS DEFAULT
OFFSITE 0 0 0
PROJECTION
"init=epsg:80000"
END
METADATA
WMS_TITLE "DRG24000"
WMS_ABSTRACT "DRG: MRR Albers"
WMS_OPAQUE "1"
END
END
### INDEX DRG 250 ####
LAYER
NAME drg24ki
TYPE line
DATA "oma24kqd.shp"
# MAXSCALE 40000
STATUS ON
PROJECTION
"init=epsg:80000"
END
METADATA
WMS_TITLE "indexdrg24k"
WMS_OPAQUE "1"
END
CLASS
SYMBOL 0
COLOR 185 211 238
OUTLINECOLOR 0 0 0
LABEL
TYPE bitmap
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE tiny
POSITION cc
WRAP "/"
END
END
END
LAYER # DOQQ data
NAME doqq24
TYPE raster
TILEINDEX "doqq.shp"
MAXSCALE 60000
STATUS DEFAULT
OFFSITE 0 0 0
PROJECTION
"init=epsg:80000"
END
METADATA
WMS_TITLE "DOQQ"
WMS_OPAQUE "1"
END
END
LAYER
NAME doqq24ki
TYPE line
DATA "doqq.shp"
# MAXSCALE 40000
STATUS ON
PROJECTION
"init=epsg:80000"
END
METADATA
WMS_TITLE "DOQQINDEX"
WMS_OPAQUE "1"
END
CLASS
SYMBOL 0
COLOR 185 211 238
OUTLINECOLOR 0 0 0
LABEL
TYPE bitmap
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE tiny
POSITION cc
WRAP "/"
END
END
END
LAYER # DOQQ data
NAME Oahe_Color
TYPE raster
TILEINDEX "oahe.shp"
MAXSCALE 60000
STATUS DEFAULT
OFFSITE 0 0 0
PROJECTION
"init=epsg:26914"
END
METADATA
WMS_TITLE "Oahe CLR"
WMS_ABSTRACT "Oahe - UTM"
WMS_OPAQUE "1"
END
END
LAYER
NAME Oahe_Col_IDX
TYPE line
DATA "oahe.shp"
# MAXSCALE 40000
STATUS ON
PROJECTION
"init=epsg:26914"
END
METADATA
WMS_TITLE "Oahe Index"
WMS_OPAQUE "1"
END
CLASS
SYMBOL 0
COLOR 185 211 238
OUTLINECOLOR 0 0 0
LABEL
TYPE bitmap
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE tiny
POSITION cc
WRAP "/"
END
END
END
end # map file
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050809/5eb0bbb0/attachment.html
