Problems with Postgis Query
Bjoern Platzen
bjoern.platzen at MOMATEC.DE
Tue Aug 9 11:05:52 EDT 2005
Hello List!
from my postgis database I need two tables to visualize a layer:
CREATE TABLE arealocation
geometryid int4 NOT NULL DEFAULT
nextval('"arealocation_geometryid_seq"'::text),
geometrie geometry,
CONSTRAINT pk_arealocation PRIMARY KEY (geometryid),
CONSTRAINT enforce_geotype_geometry CHECK (geometrytype(geometrie) =
'POLYGON'::text OR geometrie IS NULL),
CONSTRAINT enforce_srid_geometry CHECK (srid(geometrie) = -1)
WITH OIDS;
CREATE TABLE all_qu
quid int4 NOT NULL DEFAULT nextval('"all_qu_quid_seq"'::text),
qunr int4,
qust int4,
quname varchar(50) DEFAULT ''::character varying,
map_ext varchar(100) DEFAULT ''::character varying,
mapfile varchar(20) DEFAULT ''::character varying,
geometrytype varchar(25) DEFAULT 'arealocation'::character varying,
geometrie int4,
color varchar(7) NOT NULL DEFAULT ''::character varying,
recdat int8 DEFAULT 0,
cssurl varchar(100) DEFAULT ''::character varying,
"session" varchar(50) DEFAULT ''::character varying
WITH OIDS;
For each all_qu.quid there is a polygon in arealocations. The tables are
linked by the fields all_qu.geometrie and arealocation.geometryid.
The geometry_columns-table contains a row for the geometry in arealocation:
22422;"''";"public";"arealocation";"geometrie";"2";"-1";"POLYGON"
In my mapfile I've got the following statement:
DATA "geom FROM (SELECT a.quid as quid, a.quname AS name, a.color,
b.geometrie AS geom FROM arealocation b LEFT JOIN all_qu a ON b.geometryid =
a.geometrie) as foo using unique arealocation.geometryid using srid=-1"
The statement itself returns exately four rows, like it should.
Somehow, this does not work. I always get the following error-message (using
shp2img):
msDrawMap(): Image handling error. Failed to draw layer named
'plugin_Parkinfo_quartiere'. <br>
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
ation.geometryid::text from (SELECT a.quid as quid, a.quname AS name,
a.color, b.geometrie AS geom FROM arealocation b LEFT JOIN all_qu a ON
b.geometryid = a.geometrie) as foo WHERE geom && setSRID('BOX3D(2516850
5658600,2542250 5684000)'::BOX3D, -1 )' <br><br>
Postgresql reports the error as 'ERROR: column "id" does not exist
I wonder where this column "id" comes from??
I hope, that someone can help...
Thanks in advance,
Bjoern.
