Reduce Detail on Maps?
Abe Gillespie
abe.gillespie at GMAIL.COM
Tue Aug 9 17:06:27 EDT 2005
I assumed Kyle was looking for a way to antialias the jaggedness of the lines.
-Abe
On 8/9/05, Gregory S. Williamson <gsw at globexplorer.com> wrote:
> Kyle,
> Do you mean to reduce the detail in the lines themselves ?
> If you are using postgres you could perhaps use the simplify function:
> * 0.60 Simplify(geometry, tolerance)
> Returns a "simplified" version of the given geometry using
> the Douglas-Peuker algorithm. Will actually do something
> only with (multi)lines and (multi)polygons but you
> can safely call it with any kind of geometry. Since simplification
> occurs on a object-by-object basis you can also
> feed a GeometryCollection to this function. Note that returned
> geometry might loose its simplicity (see IsSimple)
> Not sure what other tools could do this ... perhaps the JUMP tool has such functionality as well, and it can work directly with shape files.
> HTH,
> Greg Williamson
> DBA
> GlobeXplorer LLC
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Kyle Mulka
> Sent: Tue 8/9/2005 12:56 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Cc:
> Subject: [UMN_MAPSERVER-USERS] Reduce Detail on Maps?
> Is there any way to reduce the detail and smooth out lines. This:
> http://mt.kylemulka.com/um.php?map=/ms4w/umbuildings.map&REQUEST=GetMap&SERV
> ICE=WMS&VERSION=1.1.1&LAYERS=Buildings&STYLES=&FORMAT=image/png&BGCOLOR=0xFF
> FFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=-83.7322998046875,42.27934093085314
> 5,-83.72955322265625,42.28137302193453&WIDTH=256&HEIGHT=256
> Just looks ugly with all the detail in it.
> -Kyle Mulka
> http://maps.kylemulka.com
> !DSPAM:42f90a033852046723401!
