Shapefile Problems
Zamil Murji
Zamil.Murji at DIVESTCO.COM
Wed Aug 10 16:49:54 EDT 2005
Hello list,
My maps have recently run into a problem with a specific shapefile. The problem just started happening (they had all been working in the past).
Here are the details:
1) Both of the attached shapefiles work in arc explorer.
2) The seis3dfill shapefile works with the specific layer in question, but the absale1 is the one that is acting up.
Here is the url in question. It returns an empty image when I use the absale1 shapefile and an image filled with polygons if I switch it to use the seis3dfill shapefile. No error msgs are produced.
http://idcmap.divestco.com/cgi-bin/mapserv?mode=map&map=/mapfiles/sdb-client-side.map&mapext=9257858.00000+2992248.10443+11712816.00000+5189146.89557&mapsize=723+647&layers=&map_seismic2d_class_expression=/(.)/&layers=&map_seismic2dlibrarycard_class_expression=/(.)/&layers=&map_seismic3d_class_expression=/(.)/&layers=&map_seismic3dlibrarycard_class_expression=/(.)/&layers=&map_seismic3d-outline_class_expression=/(.)/&layers=absale1
Here is the layer definition.
# ALBERTA SALE 1
LAYER
NAME absale1
TYPE POLYGON
STATUS off
DATA /mapdata/canada_data/landsales/absale1
# DATA ./seismic/seis3dfill
CLASSITEM 'agreement'
# CLASSITEM 'TEXT1'
# MAXSCALE 250000
LABELITEM "sale date"
# LABELITEM 'LINENAME1'
LABELMAXSCALE 200000
SYMBOLSCALE 120000
CLASS
EXPRESSION /./
OUTLINECOLOR 0 0 0
COLOR 255 149 46
SYMBOL 0
LABEL
COLOR 0 0 99
TYPE TRUETYPE
FONT arial
FORCE on
ANGLE 0.000000
POSITION cc
SIZE 5
MAXSIZE 20
MINSIZE 1
END
END
END
Any help would be appreciated.
Thanks
Zamil
