Problems with MapServer and Postgis - find_srid()
Leonardo Lamarca
lamarca at ACQUASOFTWARE.COM.BR
Thu Aug 11 14:16:28 EDT 2005
Hi everyone!
I need a help! I am running Mapserver 4.6.0 in Linux with PostgreSQL
7.4.5 and Postgis 1.0.3
I am trying to run my first web-map application using Postgis. When I
call de mapfile, MapServer return this error below.
I have an web-map application running with shape files. I converted
these shape files to PostgreSQL using shp2pgsql and change mapfile to
connect and get data through PostgreSQL.
Regards,
Leonardo Lamarca
msDrawMap(): Image handling error. Failed to draw layer named 'uf'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the
actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
REGIAO::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from public.br_uf WHERE the_geom && setSRID('BOX3D(-79.1998333333333
-33.751,-27.1691666666667 5.272)'::BOX3D, find_srid('','public.br_uf
','the_geom') )'
Postgresql reports the error as 'ERROR: find_srid() - couldnt find the
corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS
table? Is there an uppercase/lowercase missmatch? '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column
name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#'
clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of Jan 23/2004.
Part of my mapfile:
MAP
NAME "my2ndmap"
EXTENT -73.991 -33.751 -32.378 5.272
FONTSET "fontset.txt"
IMAGETYPE PNG
#SHAPEPATH "mapas"
SIZE 600 450
SYMBOLSET "symbolset.sym"
STATUS ON
UNITS DD # sim. é necessário especificar a unidade de
medida usada pelo MAP->PROJECTION
#~ PROJECTION
#~ "init=epsg:4291" # <4291> +proj=longlat +ellps=GRS67
+towgs84=-57,1,-41,0,0,0,0 no_defs <>
#~ END
WEB
IMAGEPATH "/var/www/html/my2ndmap/tmp/"
IMAGEURL "/my2ndmap/tmp/"
MINSCALE 25000
MAXSCALE 35000000
TEMPLATE "web_template.html"
HEADER "web_header.html"
FOOTER "web_footer.html"
LOG "/var/www/html/my2ndmap/log"
END
QUERYMAP
COLOR 0 0 255
SIZE 300 225
STATUS ON
STYLE HILITE
END
LEGEND
IMAGECOLOR 255 255 255
POSITION UR
KEYSIZE 12 10
STATUS ON
LABEL
ANTIALIAS TRUE
SIZE SMALL
TYPE BITMAP
COLOR 0 0 0
END
END
REFERENCE
COLOR -1 -1 -1
IMAGE "br_refmap.png"
MAXBOXSIZE 119
OUTLINECOLOR 255 0 0
SIZE 120 90
STATUS ON
END
SCALEBAR
COLOR 255 0 0
INTERVALS 3
OUTLINECOLOR 0 0 0
POSITION LR
SIZE 200 3
STATUS EMBED
STYLE 0
UNITS KILOMETERS
LABEL
ANTIALIAS TRUE
SIZE SMALL
TYPE BITMAP
COLOR 0 0 0
END
END
LAYER # uf
#~ PROJECTION
#~ END
NAME "uf"
DEBUG on
CONNECTIONTYPE postgis
CONNECTION "user=[*******] password=[*******] dbname=gis_teste01
host=localhost"
TYPE POLYGON
DATA "the_geom from public.br_uf "
STATUS DEFAULT
CLASSITEM "REGIAO"
CLASS
NAME "Norte"
EXPRESSION "NORTE"
OUTLINECOLOR 46 92 92
COLOR 0 192 0
END
CLASS
NAME "Nordeste"
EXPRESSION "NORDESTE"
COLOR 192 192 192
END
CLASS
NAME "Centroeste"
EXPRESSION "CENTROESTE"
COLOR 255 128 128
END
CLASS
NAME "Sudeste"
EXPRESSION "SUDESTE"
COLOR 255 255 128
END
CLASS
NAME "Sul"
EXPRESSION "SUL"
COLOR 128 128 255
END
END
