DWithin Filter
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri Aug 12 10:29:29 EDT 2005
Can you try upgrading to Mapserver 4.6?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Miguel Gonçalves <mgoncalves at DSI.UMINHO.PT> 08/12/05 04:26pm >>>
I am using MapServer 4.4.1.
TOLERANCEUNITS METERS is already set in the cities layer but results are
the same.
When I put the distance=0,9 I get the city that coincides with the point
but,
when I put distance=1 I get a lot of cities that are really far from the
point.
Bart van den Eijnden wrote:
>Which Mapserver version are you using?
>There was a bug with the TOLERANCEUNITS not being set. As a workaround you can try to set TOLERANCEUNITS METERS on your LAYER.
>Best regards,
>Bart
>Postbus 270
>2600 AG DELFT
>>>>Miguel Gonçalves <mgoncalves at DSI.UMINHO.PT> 08/12/05 04:11pm >>>
>I am using the WFS DWithin filter to get all the cities in a range of
>1000 meters from a point
>using the following request;
>http://localhost/cgi-bin/mapserv.exe?MAP=../mymap.map&SERVICE=wfs&VERSION=1.0.0&REQUEST=getFeature&TYPENAME=cities&Filter=
><Filter>
> <DWithin>
> <gml:Point>
> <gml:coordinates>-8.418000,41.539600</gml:coordinates>
> </gml:Point>
> <Distance units='m'>1000</Distance>
> </DWithin>
></Filter>
>In the results that I obtain the distance of the cities from the point
>is not being accurate.
>I believe I am having problems with the units.
>Can somebody help me to correct my request?
>Beste regards.
>Miguel
