DWithin Filter
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Aug 12 10:43:13 EDT 2005
Parsing of the units parameter was done for the 4.6 release (Bug
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1342).
If possible you should use 4.6 and above.
Later,
Miguel Gonçalves wrote:
> I am using MapServer 4.4.1.
> TOLERANCEUNITS METERS is already set in the cities layer but results are
> the same.
> When I put the distance=0,9 I get the city that coincides with the point
> but,
> when I put distance=1 I get a lot of cities that are really far from the
> point.
> Bart van den Eijnden wrote:
>> Which Mapserver version are you using?
>> There was a bug with the TOLERANCEUNITS not being set. As a workaround
>> you can try to set TOLERANCEUNITS METERS on your LAYER.
>> Best regards,
>> Bart
>> Syncera IT Solutions
>> Postbus 270
>> 2600 AG DELFT
>> tel.nr.: 015-7512436
>> email: BEN at Syncera-ITSolutions.nl
>>>>> Miguel Gonçalves <mgoncalves at DSI.UMINHO.PT> 08/12/05 04:11pm >>>
>> I am using the WFS DWithin filter to get all the cities in a range of
>> 1000 meters from a point
>> using the following request;
>> http://localhost/cgi-bin/mapserv.exe?MAP=../mymap.map&SERVICE=wfs&VERSION=1.0.0&REQUEST=getFeature&TYPENAME=cities&Filter=
>> <Filter>
>> <DWithin>
>> <gml:Point>
>> <gml:coordinates>-8.418000,41.539600</gml:coordinates>
>> </gml:Point>
>> <Distance units='m'>1000</Distance>
>> </DWithin>
>> </Filter>
>> In the results that I obtain the distance of the cities from the point
>> is not being accurate.
>> I believe I am having problems with the units.
>> Can somebody help me to correct my request?
>> Beste regards.
>> Miguel
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
