falling back to SRS error message
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Tue Aug 16 03:48:30 EDT 2005
hi list, hi Bart.
I had a error message: "msWMSLoadGetMapParams(): Invalid SRS given : SRS
must be valid for all requested layers."
Bart solved the problem giving:
WEB
METADATA
"WMS_SRS" "EPSG:31287 EPSG:4326"
END
PROJECTION
"init=epsg:31287"
END
LAYER
METADATA
END
Then it worked. But suddenly id doesn´t work anymore and the same error
message is displayed.
Can someone help me please?
Leopold
following the map-file and the Capabilities:
GetCapabilitiesRequest:
http://213.47.127.15:8081/cgi-bin/mapserv.exe?MAP=/ms4w/apps/maplab-2.2/tuto
rial/natura2000_epsg_2.map&SERVICE=wms&VERSION=1.1.1&REQUEST=GetCapabilities
map-file:
MAP
NAME "mmp_wms"
STATUS OFF
EXTENT 71473.4670152 40074.0096694 1251326.533 923294.99034
SIZE 800 600
SHAPEPATH "./data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 255 255 226
UNITS METERS
WEB
MINSCALE 2e+006
MAXSCALE 5e+007
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "mmp_wms_centrope_natura2000"
END
END
QUERYMAP
STATUS ON
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
PROJECTION
"init=epsg:31287"
END
LEGEND
STATUS ON
IMAGECOLOR 255 255 255
POSITION UL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE
"C:/ms4w/apps/maplab-2.2/htdocs/mapbrowser/legend_template.html"
LABEL
TYPE BITMAP
FONT "fritqat-italic"
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 300 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
LAYER
NAME "gewaesser_noe"
STATUS ON
DATA "AT_AT_NATUR_HYDSP_WATERCOURSES_2000"
TYPE LINE
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
METADATA
"wms_title" "Gewaesser_Noe"
"DESCRIPTION" "Wasser"
END
CLASS
STYLE
SYMBOL 0
COLOR 199 195 240
OUTLINECOLOR 106 105 199
SIZE 1
MINSIZE 1
MAXSIZE 100
END
STYLE
SYMBOL 0
COLOR 0 0 255
BACKGROUNDCOLOR 251 148 112
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
END
capabilities-file:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/capabilities_1_1_1.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>mmp_wms_centrope_natura2000</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://213.47.127.15:8081/cgi-bin/mapserv.exe?map=/ms4w/apps/map
lab-2.2/tutorial/natura2000_epsg_2.map&"/>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
lab-2.2/tutorial/natura2000_epsg_2.map&"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
lab-2.2/tutorial/natura2000_epsg_2.map&"/></Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/png</Format>
<Format>image/gif</Format>
<Format>image/jpeg</Format>
<Format>image/wbmp</Format>
<Format>image/tiff</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<Format>text/xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetLegendGraphic>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
<Format>application/vnd.ogc.se_blank</Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
<Layer>
<Name>mmp_wms</Name>
<SRS>EPSG:31287 EPSG:4326</SRS>
<LatLonBoundingBox minx="8.54857" miny="43.7401" maxx="25.644"
maxy="52.2016" />
<BoundingBox SRS="EPSG:31287"
minx="71473.5" miny="40074" maxx="1.25133e+006"
maxy="923295" />
<ScaleHint min="997.806" max="24945.1" />
<Layer queryable="0" opaque="0" cascaded="0">
<Name>gewaesser_noe</Name>
<Title>Gewaesser_Noe</Title>
<SRS>EPSG:31287</SRS>
<SRS>EPSG:4326</SRS>
<LatLonBoundingBox minx="14.4423" miny="47.3999" maxx="17.1214"
maxy="49.0277" />
minx="483586" miny="395428" maxx="677184" maxy="570428"
<Style>
<Name>default</Name>
<Title>default</Title>
<LegendURL width="18" height="12">
xlink:type="simple"
lab-2.2/tutorial/natura2000_epsg_2.map&version=1.1.1&service=WMS&
;request=GetLegendGraphic&layer=gewaesser_noe&format=image/png"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
