projection issue...
    Peter Giencke
    pgiencke at GLC.ORG
    Wed Aug 17 13:55:57 PDT 2005
John,
Try expliciting specifying the projection info for your layer(s) instead.
This tends to work when epsg codes do not....
Here's my template for doing this:
   PROJECTION
           "proj=lcc" #projection name
           "ellps=GRS80" #aka spheroid
           "lat_0=63" #lat of false origin
           "lat_1=49" #lat of first stp
           "lat_2=77" #lat of second stp
           "lon_0=-91.86660000" #lon of false origin
           "+x_0=6200000" #false origin easting
           "+y_0=2958000" #false origin northin
   END
 -pete
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John Cole
Sent: Wednesday, August 17, 2005 4:41 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] projection issue...
Thanks to everyone helping me to find the EPSG code, I was able to find both
the esri and epsg file in the proj directory.
Unfortunately, I had the epsg code correct (I was hoping it was wrong,
because the projection isn't working).  I'm trying to get a shapefile of the
Midwest states to work with a projected tiger county (epsg:26930).  I'm
including the prj file for both the states and my county, along with a
mapfile and an image of what I'm getting.
I've been reading and searching, and I thought this should work, but my
north Alabama county is winding up in Maine.
Any help would be appreciated.
Thanks,
John Cole
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
More information about the MapServer-users
