esri projection for wms srs value...
Tim Schaub
tim at COMMENSPACE.ORG
Wed Aug 17 21:53:44 EDT 2005
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of John Cole
> Sent: Wednesday, August 17, 2005 4:00 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] esri projection for wms
> srs value...
> PROJECTION
> "init=esri:102630"
> END
Caution to Windows folks using the ESRI codes for projections: the codes
listed in the esri file that come with the latest Windows binaries for
proj (ftp://ftp.remotesensing.org/proj/proj446_win32_bin.zip) aren't the
same as the codes you get with ArcGIS (at least v9) via
ISpatialReference::FactoryCode (some are good, some are bad). The esri
file that comes with more recent versions of proj can be used instead.
One of the hazards on relying on pre-built binaries I guess.
Tim
