oracle layers: php sometime crashes
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Aug 18 11:25:36 EDT 2005
Are you able to upgrade to Mapserver/Mapscript 4.6 and see if the problem is still there?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Francesco Sozzi <fsozzi at INTERCAD.CH> 08/18/05 05:20pm >>>
Hi all,
I have a trouble in using QueryByAttributes or QueryByShape on an Oracle Spatial layer: PHP sometime crashes.
The strange thing is that it happens only on some layer and on some PC.
I have a test installation with exactly the same php code, Apache version, Mapserver version, Oracle Version, OS version (Windows XP Professional) and on one machine works fine and on another php crashes (and only on one oracle layer, for the other oracle layers it works fine).
Has anybody already experimented a problem like this?....
Bets regards
I use:
- PHP 4.3.10
- Mapserver 4.4.1
- Apache 2
- Windows XP
The test code is:
<?php
$gMap = ms_newMapObj("C:/App/QueryMapWEB/data/AIL/gas.map");
$gLayer = $gMap->getLayerByName("Condotte");
$rectDrawnedMapCoord = ms_newrectObj();
$rectDrawnedMapCoord->setextent(716765.866548,
89471.4128114 ,
717831.590747,
87732.5996441);
$qresult = $gLayer->queryByRect($rectDrawnedMapCoord);
$layer->open();
The layer definition is:
# Condotte
LAYER
NAME "Condotte"
TYPE LINE
CONNECTIONTYPE oraclespatial
CONNECTION "ail_gas/avs at tb"
DATA "GEOM FROM (SELECT fid,geom,FROM ga_strang WHERE geom is not null AND DELETED=0) USING UNIQUE fid NONE"
STATUS DEFAULT
SYMBOLSCALE 200
CLASS
NAME "nessuna"
COLOR 0 0 0
SYMBOL 1
SIZE 8
TEMPLATE "templates/default.html"
END
END
