wfs attribute filtering
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Aug 23 10:54:14 EDT 2005
Huub,
1: add gml_include_items "all" to your LAYER's METADATA section
2: I don't expect this to work with variable subsitution
3: You can set the wfs_filter METADATA with Mapscript, I don't think you can do this with normal CGI
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Huub Fleuren <hfl at HOME.NL> 08/23/05 1:55 pm >>>
Hi List
I'm happily getting images from a wfs_filtered WFS client layer from my
map-WFS-server and i was accumulating the following questions.
1. Why are there no attributes in the response to
http://localhost/cgi-bin/mapserv/bin/mapserv.exe?map=mapserv/bin/chameleon.map&version=1.0.0&service=wfs&request=getfeature&typename=park
http://localhost/cgi-bin/mapserv/bin/mapserv.exe?map=mapserv/bin/chameleon.map&version=1.0.0&service=wfs&request=getfeature&typename=park&Filter=<Filter><PropertyIsEqualTo><PropertyName>PARK_</PropertyName><Literal>10</Literal></PropertyIsEqualTo></Filter>
2. I'm trying variable substitution in the to <ogc:filter/> but the
expression % + variable + % is interpreted litterally
http://localhost/cgi-bin/mapserv/bin/mapserv.exe?map=mapserv/bin/wfs_park.map&PARK_=10&service=wms&request=getmap&version=1.1.1&layers=wfs_park&styles=&srs=EPSG:42304&bbox=-2600000,-700000,3500000,3840000&width=610&height=450&format=png&transparent=true&exceptions=text/xml&bgcolor=0xffffff
3. How can I filter dynamically?
Regards, Huub
WFS Server layerdefinition
LAYER
NAME park
DUMP TRUE
METADATA
DESCRIPTION "Park"
END
TYPE POLYGON
STATUS ON
DATA park
CLASS
NAME "Parks"
COLOR 200 255 0
OUTLINECOLOR 120 120 120
END
TOLERANCE 5
END # Layer
WFS Client layerdefinition
LAYER
NAME wfs_park
TYPE POLYGON
STATUS ON
CONNECTIONTYPE WFS
CONNECTION
"http://localhost/cgi-bin/mapserv/bin/mapserv.exe?map=mapserv/bin/chameleon.map"
#adding a Filterkeyword works, but also not applicable to variable
substitution
#&Filter=<Filter><PropertyIsEqualTo><PropertyName>PARK_</PropertyName><Literal>%PARK_%</Literal></PropertyIsEqualTo></Filter>"
METADATA
"wfs_typename" "park"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "60"
"wfs_maxfeatures" "50"
"wfs_filter"
"<PropertyIsEqualTo><PropertyName>PARK_</PropertyName><Literal>%PARK_%</Literal></PropertyIsEqualTo>"
# "wfs_filter"
"<PropertyIsEqualTo><PropertyName>PARK_</PropertyName><Literal>10</Literal></PropertyIsEqualTo>"
END
PROJECTION
"init=epsg:42304"
END
CLASS
STYLE
COLOR 0 255 0
END
END
END
