AW: [UMN_MAPSERVER-USERS] attribut values
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Wed Aug 24 03:16:48 EDT 2005
Hi Travis, thank you for your advice to make a map file for several classes.
I tried to make some for my file of inhabitant-density with two classes >200
and <200. (Mapfile in the Attachement)
But I get the error message 'msDrawMap(): Failed to draw layer named
'Bev_Density' '.
Is it right, that you don't have the line 'CLASSITEM "EWKM2"' in you map
file?
best regards - Leopold
-----Ursprüngliche Nachricht-----
Von: Travis Kirstine GIS Tech [mailto:tkirstine at jdbarnes.com]
Gesendet: Dienstag, 23. August 2005 14:32
An: Leopold Schefcik (MULTIMEDIAPLAN.AT)
Betreff: RE: [UMN_MAPSERVER-USERS] attribut values
Leopold
If you are trying to display a layer with several classes you can try
something like this:
LAYER
DATA mattamy/road_web
NAME roads
METADATA
DESCRIPTION "Roads"
END
TYPE LINE
STATUS ON
MAXSCALE 150000
MINSCALE 40001
LABELMAXSCALE 120000
LABELMINSCALE 500
LABELITEM "STREETNAME"
CLASS # HIGHWAYS/MAJOR ROADS
MAXSCALE 120000
MINSCALE 500
EXPRESSION ([RD_CLASS]=1) #if it is a string ('[FIELD]'='value')
SYMBOL 1
COLOR 75 75 75
SIZE 1
END
CLASS # SECONDARY ROADS
MAXSCALE 120000
MINSCALE 40001
EXPRESSION ([RD_CLASS]=2)
SYMBOL 1
COLOR 100 100 100
SIZE 1
END
CLASS # LOCAL ROADS
MAXSCALE 80000
MINSCALE 40001
EXPRESSION ([RD_CLASS]=3)
SYMBOL 1
COLOR 150 150 150
SIZE 1
END
END
You can also check out http://ms.gis.umn.edu/docs/reference/mapfile
Travis
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Leopold Schefcik (MULTIMEDIAPLAN.AT)
Sent: Tuesday, August 23, 2005 8:01 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] attribut values
Hi list,
I have a database for a layer conisting of 5 files:
test_bevdichte3.dbf
test_bevdichte3.sbn
test_bevdichte3.sbx
test_bevdichte3.shp
test_bevdichte3.shx
In my map file I can give the path to the dbf file to clasify the data.
CLASSITEM "EWKM2"
but still oll the polygones have the same color.
Somehow I want to configurate how many classes are build and with stile
every class has.
Somebody can give my a hint?
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050824/ddda0af3/centrope_wms_bevdichte.obj
