AW: satellite-picture
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Wed Aug 24 04:48:41 EDT 2005
Hi Bart,
I made the first step and changed the settings as you said. Now I don't have
a error message anymore (so path should be ok), but I also don't see the
satellite picture.
http://213.47.127.15:8081/mapbender/frames/login.php?&gui_id=pgo_centrope&na
me=centrope_user&password=pgo
(the satellite layer is the last one and should be about over Vienna in the
middle of the map)
Best regards,
Leopold
(map-file in attachement)
-----Ursprungliche Nachricht-----
Von: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
Gesendet: Mittwoch, 24. August 2005 09:55
An: MAPSERVER-USERS at LISTS.UMN.EDU; leopold.schefcik at MULTIMEDIAPLAN.AT
Betreff: Re: [UMN_MAPSERVER-USERS] satellite-picture
Hi Leopold,
I can partially answer your question.
Use TYPE RASTER and DATA "wienumgebung.tif". Make you sure you include the
right path to your tif file.
I don't know if Mapserver (GDAL) can read the rrd files which are Erdas
files if I am not mistaken for pyramids, but if you are worried about
performance you can always make internal overviews in your tiff file using
gdaladdo.
gdaladdo -r average abc.tif 2 4 8 16
I would suggest looking at the Raster HOWTO:
http://mapserver.gis.umn.edu/doc46/raster-howto.html
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)"
<leopold.schefcik at MULTIMEDIAPLAN.AT> 08/24/05 09:45 AM >>>
Hi list,
I have a satellite-picture conisting of 4 files:
wienumgebung.aux
wienumgebung.rrd
wienumgebung.tfw
wienumgebung.tif
1. How can I make it shown? I tried to put it in a map file like this
(attachement) but for example I don't know what to put in 'TYPE ????'
2. The whole database is a file about 1,7 GB. My testfile wienumgebung.tif
has only about 60 MB. - I think the Gis programm makes the files aux and rrd
to split the big file in a tree of files with different solutions for
different zoom faktors. How can I intergrate them to let my whole satellite
picture be shown in each zoom/solution?
best regards - Leopold
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050824/3a852212/centrope_wms_sat_wien.obj
