Making a WMS layer queryable
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Aug 24 18:55:11 EDT 2005
You need WFS for querying feature attributes.
-e
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jennifer Zeisloft
Sent: Wednesday, August 24, 2005 4:13 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Making a WMS layer queryable
Hello All-
I am attempting to serve a WMS layer that I would like to be
queryable (using the identify feature button/Query widget from
Chameleon). The layer appears as it should when brought into a map, but
is not queryable, despite what it says in the layer information popup
window. Other layers brought into the same map through other servers
are queryable. I have searched the documentation and lists, but haven't
been able to find any answers. Do I need to add something extra to the
mapfile (layer portion is pasted below)? Both the context and
capabilities xml files show that the layer is queryable (=1) and I have
increased the tolerance ridiculously just to make sure a click hits on
the point. Any suggestions would be greatly appreciated! Thanks in
advance for your help.
Jennifer Zeisloft
UW Sea Grant
LAYER
NAME Bluff_Profile
STATUS ON
TYPE POINT
DATA bluffg
TEMPLATE "ttt_query.html"
TOLERANCE 500
TOLERANCEUNITS PIXELS
MAXSCALE 300000
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "Bluff_Profile"
"wms_title" "Bluff Profiles"
"wms_abstract" "TBA"
"wms_keywordlist" "Lake Superior"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png,image/jpeg,image/wbmp"
"wms_format" "image/png"
"wms_onlineresource"
"http://144.92.46.35/cgi-bin/mapserv.exe?map=C:\ms4w\apps\chameleon\lscm
p\map\wlscmp_wms.map& "
END
CLASS
SYMBOL 'circle'
COLOR 255 166 0
SIZE 6
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050824/cecf52df/attachment.html
