oke results on monday. Regards, Huub Bart van den Eijnden wrote: >Huub, > >you need to compile mapserv with VC6, SP3 or SP4 minimal (one of the two, I can't remember exactly). Otherwise you get crashes on GetFeatureInfo or GetFeature with maporaclespatial. VC7 also does the trick. > >
