print option
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Aug 25 11:14:13 EDT 2005
There is also a very extended print functionality in Chameleon based on PHP/Mapscript.
See www.maptools.org/chameleon
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Dirk-Jan Huisman <d.huisman at INGBCC.NL> 08/25/05 5:03 pm >>>
Is used freeware pdflib from http://www.fpdf.org/
I never make a complete print function. Only draw a map. I haven't got
time work it out.
But there is enough information on http://www.fpdf.org/
best regards
-----Oorspronkelijk bericht-----
Van: Carlos Eduardo Sibaja Salazar
[mailto:carloseduardo at COSTARRICENSE.CR]
Verzonden: donderdag 25 augustus 2005 16:52
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] print option
Thanks to everyone for your help about the print option.
I'm using the example sent by Piero Cavalieri. It works fine but i have
a
problem with the library pdflib, because when i print a map, a message
showing this "www.pdflib.com" is printed over the map crossing the page.
I found this explanation in www.pdflib.com:
"PDFlib, PDFlib+PDI, and PPS are distributed as one single binary
package
which is fully functional, but displays a demo stamp across all
generated
pages unless a valid license key is applied."
I'm not sure if i have to buy the license key or there are some free
options.
Please tell me what i have to do.?
Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
E-mail post at ingbcc.nl
Internet www.ingbcc.nl
Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
