Blank image being created in MS 4.6.0
Matthew Edmondson
matt0177 at GMAIL.COM
Thu Aug 25 14:12:10 EDT 2005
Try setting the Transparency lower then 100
Matt Edmondson
On 8/25/05, Mike Boos <mboos at augsignals.com> wrote:
> Hello
> I'm trying to upgrade our map server from version 4.1 to 4.6.0 and am
> facing some hurdles. The map files work fine in version 4.1, but are all
> generating blank white images for me in 4.6.0. From reading the mailing
> lists and the documentation, I can't seem to find what's wrong with the
> map files. Here's an example:
> #epsg:32611
> NAME AUG21234542.map
> SIZE 400 400
> EXTENT 0 0 576 432
> WEB
> TEMPLATE ../mapServerTemplateVis.html
> IMAGEPATH ""
> IMAGEURL ""
> END
> LAYER
> TYPE RASTER
> STATUS DEFAULT
> DATA "C:\inetpub\ftproot\input_images\AUG162454635.jpg"
> PROJECTION
> "init=epsg:32611"
> END
> TRANSPARENCY 100
> END
> END
> Does anyone know what changes I need to make to have the image appear on
> my map?
> Thanks
> Mike Boos
