Two Keymaps??
Jennifer Zeisloft
jzeisloft at GMAIL.COM
Tue Aug 30 00:09:28 EDT 2005
Hello All-
I am playing with including two keymaps in my application (one that is more
useful when zoomed in, and one when zoomed out). They would be displayed
simultaneously. I am having some trouble doing this, though it doesn't seem
like it should be too tough.
I am also using Chameleon (the Keymap DHTML widget). However, I think my
first task towards accomplishing this would be on the MapServer end. When I
place a second Reference object in the mapfile, I receive the error that
there is a dupilcate item:
*Warning*: [MapServer Error]: getString(): Duplicate item (IMAGE):(line 49)
in *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php* on line *
215*
*Warning*: Failed to open map file
C:\ms4w\apps\chameleon\lscmp\htdocs/../map/wlscmp.map in *
C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php* on line *215*
*Fatal error*: Call to a member function on a non-object in *
C:\ms4w\apps\chameleon\htdocs\widgets\KeyMapDHTML\KeyMapDHTML.widget.php* on
line *115
Might there be a simple solution? Or would I need to rewrite a bunch of code
somewhere (if so, where?)? I would really appreciate any hints you can pass
along. Thanks in advance for your help!
Jennifer Zeisloft
UW Sea Grant
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050829/136a0b0d/attachment.html
