WFS DescribeFeatureType in mapserv4.6
    Bart van den Eijnden
    BEN at SYNCERA-ITSOLUTIONS.NL
    Tue Aug 30 05:23:02 PDT 2005
Use gml_include_items "all" in your LAYER's METADATA section.
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Tomas Novotny <tomas.novotny at TMAPY.CZ> 08/30/05 1:44 pm >>>
Hi all,
after I moved from MapServer 4.4.1 to 4.6.0 I have problem using WFS DescribeFeatureType request.
I normally used mapserv 4.4.1 for getting information about layer attributes. But 4.6.0 returns no attribute information at all.
Here are examples that ilustrate my problem:
DescribeFeatureType response on 4.4.1:
<schema targetNamespace="http://www.ttt.org/myns"
elementFormDefault="qualified" version="0.1">
<import namespace="http://www.opengis.net/gml"
schemaLocation="http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd"/>
<element name="vodni_plochy" type="myns:vodni_plochy_Type"
substitutionGroup="gml:_Feature"/>
    <complexType name="vodni_plochy_Type">
    <complexContent>
    <extension base="gml:AbstractFeatureType">
    <sequence>
<element ref="gml:polygonProperty" minOccurs="0"/>
<element name="AREA" type="string"/>
<element name="VODY_ID" type="string"/>
<element name="TYP_VPL" type="string"/>
<element name="NAZEV" type="string"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
And DescribeFeatureType response on 4.6.0 (with the same data source):
<element name="vodni_plochy" type="myns:vodni_plochyType"
<complexType name="vodni_plochyType">
<complexContent>
<sequence>
<element name="msGeometry" type="gml:GeometryPropertyType" minOccurs="0"
maxOccurs="1"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
Maybe the problem is in bad compilation.
I will appreciate every reaction.
Tomas
More information about the MapServer-users
