How do I embed any text onto the map
Steve Lime
steve.lime at DNR.STATE.MN.US
Fri Dec 2 01:32:33 EST 2005
Hi Aniruddha: The way to do that is using inline layers. For example:
LAYER
NAME 'copyright'
TYPE ANNOTATION
STATUS DEFAULT
TRANSFORM FALSE # coordinates are in pixels
FEATURE
POINTS 10 10 END
END
CLASS
LABEL
SIZE MEDIUM
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION CR
END
TEXT 'Copyright 2005'
END
END
This would place the text 'Copyright 2006' towards the upper-left hand corner of the map, just to the right of the pixel coordinate 10,10. You could do similar things with a custom string:
- you can alter the CLASS TEXT dynamically with run-time subsitutions (e.g. TEXT '%title%')
and a north arrow marker:
- use a POINT layer that references a north arrow graphic in the CLASS STYLE
The problem you'll run into is that inline pixel coordinates are absolute so they really only work with one image size. (except for the UL corner which is always 0,0) The only solution there is to either have 1 mapfile for each image size you need. You could muck with the coordinates at runtime possibly too.
Ideally we'd allow relative pixel coordinates some like:
FEATURE
RELATIVETO LR
POINTS -50 -50 END
END
Which would give you a point just inside the lower right-hand corner, but alas it has not been implemented. (not a bad idea and not that hard- I'll file a bug now).
Steve
>>> "Aniruddha S. Khadkikar" <as.khadkikar at NCL.RES.IN> 12/01/05 11:34 PM >>>
I am unable to resolve how to add any text on the map.
I wish to add the following elements:
1. Copyright statement for the image produced.
2. North Symbol
3. Dynamic text e.g. Name of the species for which the distribution map
is being generated.
I am providing an option for downloading the image at 100, 200,300 dpi.
I am using pmapper for the project. So it is necessary that the final
jpg file have all these details on the image itself. All the above
elements will be 'relatively' fixed on the map. i.e. I want the name on
the upper left corner, north symbol and copyright statement towards the
upper right corner of the map.
I hope I am clear.
Aniruddha
ANIRUDDHA S. KHADKIKAR Ph.D.
Digital Information Resource Centre
National Chemical Laboratory
Dr. Homi Bhabha Road
Pune 411008, INDIA
Phone : 91 020 25893457 (Off)
Fax : 91 020 25893973
Email : as.khadkikar at ncl.res.in
Web : http://www.ncbi.org.in
This email is virus free by TrendMicro Inter Scan Security Suite.
