PostGIS error on 4.8b2
Howard Butler
hobu at IASTATE.EDU
Sat Dec 10 15:49:42 EST 2005
Is <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1443> still
relevant to this issue (issues with using *both* UNIQUE and SRID)?
Howard
At 12:33 PM -0800 12/10/05, Paul Ramsey wrote:
>Well, the error is unhelpful, and I am not sure why your data
>statement is failing. It is functionally equivalent to
>DATA "wkb_geometry FROM my_funky_table USING UNIQUE ogc_fid USING
>SRID=26910"
>So I don't know why you are nesting the SQL in this case. Still it
>should work. Turn on statement logging in postgresql and see if
>anything is making it to the database at all.
>P
>On 9-Dec-05, at 6:33 PM, Ken Lord wrote:
>> I haven't seen a response to this variation of the postgis / 4.8b2
>> issue yet, as posted by someone else.
>> Has anyone figured out how to use PostgreSQL 8.0.3 / PostGIS 1.0.4
>> with MapServer 4.8b2?
>> I have an OID column, I'm not using PostgreSQL 8.1. But my DATA query
>> is rejected with an error near USING ...
>> If I use another unique column present in the table, it produces the
>> same error. This query did work with mapserver 4.6.
>> Here's my DATA string:
>> DATA "wkb_geometry FROM (SELECT * FROM my_funky_table) AS foo USING
>> UNIQUE ogc_fid USING SRID=26910"
>> And here's the error:
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'Funky_Table'
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051210/748bf8ae/attachment.html
