PostGIS error on 4.8b2
Sean Gillies
sgillies at FRII.COM
Sat Dec 10 22:14:24 EST 2005
Ken,
Cc yourself to bug 1443. I committed a fix for it and would
appreciate confirmation.
Sean
On Dec 10, 2005, at 8:05 PM, Ken Lord wrote:
> Here's a temporary fix that may work for certain users for the USING
> error for PostgreSQL 8.0.3 - PostGIS / mapserver 4.8b2 until the
> problem is patched.
> If your dataset is in the same map projection as your output map,
> simply remove the 'USING srid=3Dxxxxx' from the end of your SQL
> query in
> your DATA string.
> You will again be able to use nested select statements for datasets
> based on on-the-fly spatial queries etc.
> As Daryl Herzmann appears to have discovered, the current bug prevents
> mapserver from dealing with more than one USING tag in your SQL.
> Paul - Instead of waiting til Monday, I replicated the problem by
> upgrading my cariboo-gold.no-ip.info website to MS 4.8b2, to try your
> suggestion of turning on statement logging.
> - The log shows the same error seen on the webpage '.... syntax error
> at or near "USING" at character ...' So the database is receiving the
> request.
> And without the 'USING srid=3Dxxxxx' in the SQL statement, each map
> request crams the log with ~30 lines reffering to the 'find_srid'
> function ... but the map generates properly.
> Cheers,
> Ken Lord
> Vancouver BC
> On 12/10/05, Ken Lord <kenlord at gmail.com> wrote:
>> Thanks Daryl,
>> I saw your patch there, unfortunately I'm one of those hobbled
>> people
>> living in the windows world, who hasn't learned how to compile the
>> software.
>> So it will be 4.8b3 or beyond for me :)
>> Cheers,
>> Ken Lord
>> Vancouver BC
>> On 12/10/05, Daryl Herzmann <akrherz at iastate.edu> wrote:
>>> On Sat, 10 Dec 2005, Ken Lord wrote:
>>>> Thanks Howard,
>>>> That bug does seem to cover my problem, I've added a post to the
>>>> report to confirm that it affects more than just postgresql 8.1 +
>>>> mapserver 4.8b2.
>>>> Paul, I'll try your suggestion on Monday. I had simplified my SQL
>>>> statement when trying to make it work, evidently I could have
>>>> simplified it more :)
>>>> On 12/10/05, Howard Butler <hobu at iastate.edu> wrote:
>>>>> Is <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D1443>
>>>>> still relevant to this issue (issues with using *both* UNIQUE
>>>>> and SR=
> ID)?
>>> Hi Ken,
>>> I am nearly positive if you apply my patch included in that bug,
>>> Postgi=
> s
>>> with "USING..." in the data statement will work...
>>> Hopefully that patch, in some form, is accepted before the next
>>> release=
>>> daryl
>>> * Daryl Herzmann (akrherz at iastate.edu)
>>> * Program Assistant -- Iowa Environmental Mesonet
>>> * http://mesonet.agron.iastate.edu
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
