Shapefile layer filter to sort objects ?
Laurent Jégou
jegou at UNIV-TLSE2.FR
Mon Dec 12 05:29:55 EST 2005
Hi list,
I'm using the SIZEITEM parameter of the STYLE object to generate
proportional symbols based on attributes values. It's working nicely
since i discovered that the SYMBOLSCALE parameter of the LAYER object
must be present. I'm now wondering if there's a way to sort the symbols
objects in decreasing order, to have the small ones drawn above the big
ones. With a database geometry source i can use a FILTER parameter, but
with a shapefile source ?
Thanks for your help,
Laurent
Laurent Jégou
IGE Cartographe
UTM - Dépt. Géographie
31058 TOULOUSE Cedex 9 - 05.61.50.43.89
http://www.univ-tlse2.fr/geoprdc
http://www.geotests.net/blog
