querybyshape and contain
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Dec 13 21:30:40 EST 2005
This is not possible with the given code. PostGIS gives you this functionality. It is pretty easy to add though- if using MapScript. All we'd need to do would be to expose a couple of additional GEOS operators (like contains) and you could do something like:
Step 1: query by rect (using the query shape extent)
Step 2: for each result feature actually test using the contains operator
Let me know if you'd like to pursue...
Steve
>>> Fx Gamoy <fx.gamoy at GEOMATIKA.FR> 12/13/05 11:20 AM >>>
Hello everybody
i would like to query a layer with a shape in order to get all the objs
contained in the shape
When i use querybyshape, i get all the objs intersected by the shape.
So some objs are not selected.
Is it a way to get a spatial contain query instead of an intersect one?
thanks for your help
fx
This message was sent using IMP, the Internet Messaging Program.
