query on shapes
Ken Lord
kenlord at GMAIL.COM
Mon Dec 19 12:26:33 EST 2005
Hi Mauricio,
Please post to the list the problem layer from your mapfile.
You may not be clicking on the map close enough to a feature for the
query to work, or your tolerance may be set too low or with units that
are not appropriate so that nothing is returned even if it looks like
you are clicking right on the feature, or perhaps you have left out
the header / template parameters for the layer.
Cheers,
Ken
On 12/19/05, Mauricio Stange H. <mstangeh.foros at gmail.com> wrote:
> Hi,
> I use a classitem of the shape for setting diferent styles, but when I
> query that layer, I give me "The following layers did not return any
> results:" and in the list is my layer. Do I have to set a property of the
> layer to display the data of the shape??. For the query I'm using the
> template that is generated with mablab. I have another layer wich get his
> data from postgis, and the query works fine. So…, where is the problem…???
> Thanks,
> Mauricio Stange H.
