Announcement - MapServer Browser Client (Another one)
David Bitner
osgis.lists at GMAIL.COM
Thu Dec 22 10:16:37 EST 2005
I have seen some demos of GISmo. It's a great interface and I would
love to get my hands on some of the code.
David
On 12/21/05, Dean C. Mikkelsen <dcmikkelsen at shaw.ca> wrote:
> Hi there.
> I have not responded in quite some time to the list, but having been
> following the comings and goings quite a lot.
> I think that this would be a good addition to the community.
> For myself, a simple demonstration site would be useful - to show the type
> of functionality that we should be able to implement once the code is
> available to the community.
> I do like I what I see in the images provided.
> Cheers,
> Dean
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Bob Basques
> Sent: Wednesday, December 21, 2005 3:34 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Announcement - MapServer Browser Client
> (Another one)
> All,
> I'm looking for feedback on the following. We've put a Simple but
> powerful Web Interface together in our office that builds against
> MapServer-CGI. We would like to put the Code out into the Community as
> we think it has a lot of potential.
> I'm making this Project (proposal) Announcement here first to gage
> interest. I've put up a few screen shots as well with links intersprsed
> in this message. Depending on Interest we'll put up a Simple demo as a
> follow-up, are there suggestions for a data set to use? I could use the
> MapServer Demo, or????
> Thanks and read on . . . .
> Announcement of "GISmo" for MapServer (and other Raster Map Services)
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss1.jpg
> "GISmo" is the name, and Map viewing is the game.
> The City of Saint Paul, Public Works has been using MapServer for
> Mapping Distribution via the Web for a little over two years now with
> outstanding results. Our needs list was short but finite.
> * How to distribute up-to-date mapping data.
> * Enable the data owners to maintain their own data sets for
> distribution and provide an easy publishing mechanism.
> * Use one source of data (MapServer) for all Clients. We
> implemented the system for Internet Browsers as well as AutoCAD
> User sessions, and it
> can be extended to other formats/clients as needed.
> * The User Interface needed to be very Simple to operate, little to
> no training required in it's use.
> * Ability to integrate with other Web Based Systems.
> The list above looks short but it did have it's problems with
> implementation. We went through a couple of different versions before
> getting to where we are now. What we have now is a good base to start
> from and seems like the logical point to present it to a larger
> audience, the MapServer Community.
> GISmo is a XML based web Client for viewing MapServer Web Services or
> any other Raster based Service, for that matter.
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss2.jpg It
> could easily be extended to handle WMS calls for example. This Client
> Page gets it's Imagery from The MapServer via a MAP file but using a
> separate Map File per layer. Something akin to WMS only inside of a
> single MapServer Service. This can be extended to hit other MapServer
> Services as well BTW. Assuming there is interest to proceed with
> development further (we're going to keep moving on it internally either
> way) it may suggest some different ways to handle the MapServer Map file
> Layouts. http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss2.jpg
> Short list of the Capabilities of the "GISmo" package:
> * User Customizable Catalog View (assuming you know XML, the plan is
> to build a Catalog maker as well)
> * Cross-Browser
> o FireFox 7 (tested)
> o IE( tested)
> o Should work for the most part in Opera too
> * Multiple layer Control
> o external to the MapServer, IE a layer can break and the
> whole service keeps on running, this allows for data
> administrators
> to update their respective layers at will)
> o The layers are assembled in the Browser via DHTML stacking,
> so only the images are retrieved once the interface is loaded,
> and only the images after that.
> * XML based Main Page
> o Can originate as a local page for those that want to make
> their own view into the available Layers.
> o Settings for Initial view parameters for each layer.
> (ON/OFF, FADE-Value, etc)
> * GISmo view Panes.
> o Layer "Catalog" Chooser View
> + Cascaded Layer listings
> o "Visible Layers" Control
> + Layer Stacking ("Z" value of layer) user Control.
> + opacity control (fading of individual layers)
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss3_bg-unfaded.jpg
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss3_bg-faded.jpg
> o Map Layer View
> + Automatic re-sizing of the Map View upon browser re-size.
> + Attribute Viewer based on MapServer Templating of a
> IMAGEMAP.
> + ToolTip Popups for ImageMaps on a per layer Basis.
> These ImageMaps can be swapped out for viewing by the Users in the
> client for each View limit.
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss3_popup.jpg
> + Sticky Tooltips
> * Systems Integration Hooks to other (non-spatial) data services.
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss4_infra1.jpg
> o Sticky Tools Tips contain HTML code for linking to other
> Systems, a Field Photo in this Case:
> http://pwultra5.ci.stpaul.mn.us/tmp/gismo_images/gismo_ss4_infra2.jpg
> The Client is DHTML with multiple transparent Layers on top of one
> another. There is no middle ware required unless you consider the
> multiple Map files a middle ware piece. Other than the MapServer Web
> Service, there is no requirement for any additional service, this is not
> to say that other services can't be hooked to, because we are internally
> hooking into three other services that are spatially enabled with our
> GISmo interface, a Infrastructure Maintenance Management Tool, An
> Address Lookup/Geocoding Tool, and a Field Photography lookup tool that
> can be easily converted into a Simple Document Management tool that is
> spatially enabled (Think Documents with a Spatial Index). Some of these
> other tools may be considered for additional projects to submit to the
> Community as well, but I thought we should just start out slow.
> The back end data storage is a shared Folder structure with assigned
> Folder for SHP/MAP file and Database/MAP file locations. With this
> Folder structure in place, each Data layer owner has complete control
> over their respective data layer and how often it's updated. The Front
> end Catalog "MapBook" description is simply a XML file that describes
> the basics of where the MAP files for MapServer are located and some
> basic view parameters for use during startup of the interface. See the
> end of this message. This simple XML file can originate externally to
> the MapServer Web Service. It allows a Admin to set up and interface
> with just the layers they are interested in displaying.
> Basically, the components are as standalone as possible and don't depend
> on each other where ever possible. All services can be run
> independently of one another.
> We're prepared to put this code out (giving back to the MapServer
> Community) as Open source. We're actively using these JavaScript LIBs
> internally, and can put together a sample database for use. I may even
> modify one of the Sample datasets distributed with MapServer to work
> with this interface. The Libs that are distributed to this Open source
> effort will be the same one we use internally so they will be kept up as
> we modify/bug-fix them.
> All that's required for set will be a separate Map File per viewable
> layer desired. Internally we have assigned folders with a somewhat
> strict Folder tree that denotes Ownership, Type of Data, Responsibility,
> and date of data release.
> We'll be setting up a Demo service within the next couple of weeks to
> gage feedback on whether we should proceed.
> There are also some complimentary utilities (mostly PERL based) :
> * "Fusion" - Print facility that takes the separate images and fuses
> them together into a single image for printing. We're adding onto
> this a PDF output format
> Basic structure looks like this:
> XML
> \--XSL
> |--Client Code (Page Origination, Catalog description)
> |--URL.JS - Resizing and Map Population controller
> |--OPACITY.JS - Layer Opacity controller
> |--DUCKLOADER.JS -
> |--POPUPS.JS - ToolTip Controller
> |--POINTMANAGER.JS -
> \--MENUS.JS -
> Thanks
> Bob Basques
> GIS Systems Developer - Public Works
> 25 West 4th Street, 1000 CHA
> City of Saint Paul, Mn 55102.
> XML "Map Book" File:
> <?xml version="1.0"?>
> <?xml-stylesheet type="text/xsl" href="./gambit_rlb.xsl"?>
> <mapbook title="GISmo2">
> <group title="Administrative and Political Boundaries">
> <map title="Cities" zindex="10" opacity="50">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/CITIES/cities_ramseymn-f.map
> </file>
> </map>
> </group>
> <group title="Elevation">
> <map title="contours_1ft">
> <file>
> /pearl/DB/SAINT_PAUL/PUBLIC_WORKS/CONTOURS/contours_1ft.map
> </file>
> </map>
> </group>
> <!--<group title="Base Maps, Scanned Maps and Charts">
> </group>-->
> <group title="Imagery and Photographs">
> <!-- <map title="geospan">
> <file>
> /pearl/DB/SAINT_PAUL/PUBLIC_WORKS/GEOSPAN/geospan.map
> </file>
> </map>-->
> <service name="geospan" title="Street Level Photos -
> GEOSPAN" points="1">
> <url>/gis/geospan/cgi-bin/geospan.pl</url>
> <input type="layers" name="layers"/>
> <point type="combined" name="point"/>
> <input type="hidden" name="r_min" value="10"
> title="Minimum Distance from Picture"/>
> <input type="hidden" name="r_max" value="100"
> title="Maximum Distance from Picture"/>
> <input type="hidden" name="theta_tol" value="30"
> title="Degrees from centre of Picture"/>
> </service>
> <map title="Aerial Photos 2003 - Horizons" zindex="-1">
> <file>
> /pearl/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_HORIZONS/horizons_2003.map
> </file>
> </map>
> <map title="Aerial Photos 2001 - Kodak Citipix" zindex="-1">
> <file>
> /pearl/RASTER/SAINT_PAUL/PUBLIC_WORKS/AERIAL_CITIPIX/citipix_2001.map
> </file>
> </map>
> <map title="Aerial Photos 1985 - RCSWCD" zindex="-1">
> <file>
> /pearl/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1985.map
> </file>
> </map>
> <map title="Aerial Photos 1974 - RCSWCD" zindex="-1">
> <file>
> /pearl/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1974.map
> </file>
> </map>
> <map title="Aerial Photos 1953 - RCSWCD" zindex="-1">
> <file>
> /pearl/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1953.map
> </file>
> </map>
> <map title="Aerial Photos 1940 - RCSWCD" zindex="-1">
> <file>
> /pearl/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1940.map
> </file>
> </map>
> </group>
> <group title="Water Resources (INLAND)">
> <map title="Lakes and Rivers">
> <file>
> /pearl/SHP/MINNESOTA/MNDOT/LAKES/lakes.map
> </file>
> </map>
> </group>
> <group title="Geodetic Networks and Control Points">
> <map title="Property Lines">
> <file>
> /pearl/RASTER/SAINT_PAUL/PUBLIC_WORKS/PROPERTY/property.map
> </file>
> </map>
> <map title="Benchmarks">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/BENCHMARKS/benchmarks.map
> </file>
> </map>
> <map title="Monuments">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/MONUMENTS/monuments.map
> </file>
> </map>
> </group>
> <group title="Land Ownership">
> <map title="Parcels - Rubbersheeted" opacity="50">
> <file>/pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/PARCELS/parcels_rubber.map</file>
> </map>
> </group>
> <!--<group title="Planning and Development">
> </group>
> <group title="Recreation and Tourism">
> </group>-->
> <group title="Facilities, Buildings and Structures">
> <group title="Bridges">
> <map title="Bridge Outlines">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/BRIDGES/bridge_maps.map
> </file>
> </map>
> </group>
> <group title="Planimetrics">
> <map title="planimetrics_lines">
> <file>
> /pearl/SHP/RAMSEY_COUNTY/PUBLIC_WORKS/PLANIMETRICS/planimetrics_lines.map
> </file>
> </map>
> <map title="planimetrics_poly">
> <file>
> /pearl/SHP/RAMSEY_COUNTY/PUBLIC_WORKS/PLANIMETRICS/planimetrics_poly.map
> </file>
> </map>
> </group>
> </group>
> <group title="Transportation">
> <map title="Streets (TLG)" default="true">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/CENTERLINES_TLG/tlg01.map
> </file>
> </map>
> <map title="Streets (TLG) With Address Ranges"
> default="true">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/CENTERLINES_TLG/tlg01_add_ranges.map
> </file>
> </map>
> <group title="Traffic Operations">
> <map title="Signals">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/SIGNALS/signals.map
> </file>
> </map>
> <map title="Signs">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/SIGNS/sign_points.map
> </file>
> </map>
> <map title="Stripings">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/PAVEMENT_STRIPINGS/stripings.map
> </file>
> </map>
> <map title="Markings">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/PAVEMENT_MARKINGS/markings.map
> </file>
> </map>
> <map title="Street Lights">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/LIGHTING/lighting.map
> </file>
> </map>
> <map title="Intersections">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/INTERSECTIONS/intersections.map
> </file>
> </map>
> <map title="Parking Meters">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/METERS/meters_parking.map
> </file>
> </map>
> </group>
> </group>
> <group title="Utilities and Communications">
> <group title="Sewers">
> <map title="Catch Basins">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/CATCHBASINS/catchbasins.map
> </file>
> </map>
> <map title="Sewer Permit Points">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/SEWERS/permit_points.map
> </file>
> </map>
> <map title="Sewer Test">
> <file>
> /pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/SEWERS/sewer_test.map
> </file>
> </map>
> </group>
> <group title="Water Supply">
> <map title="Mains">
> <file>
> /pearl/SHP/SPRWS/MAPPING/MAIN/main.map
> </file>
> </map>
> <map title="Hydrants">
> <file>
> /pearl/SHP/SPRWS/MAPPING/HYDRANT/hydrant.map
> </file>
> </map>
> <map title="Valves">
> <file>
> /pearl/SHP/SPRWS/MAPPING/CONTROL_VALVE/control_valve.map
> </file>
> </map>
> </group>
> </group>
> <group title="Annotation">
> <map title="Scale Bar" default="true">
> <file>
> /usr/local/GIS/gambit/mapfiles/scalebar.map
> </file>
> </map>
> </group>
> <group title="Places and Things">
> <view title="Zoom To County"
> >539368,134025,604711,222260</view>
> <view title="Zoom To City"
> status="default">544668,135639,598640,174180</view>
> Downtown">572682,155285.5,578462,160037.5</view>
> <map title="Selected Point" status="invisible">
> <file>
> /usr/local/GIS/gambit/mapfiles/point.map
> </file>
> </map>
> <service name="fido" title="Find Asset by ID" points="0">
> <!-- <url>/gis/fusion/cgi-bin/fusion.pl</url>-->
> <url>/gis/fido/cgi-bin/fido.pl</url>
> <input type="user" name="id" value="" title="ID:"/>
> </service>
> <link title="STAMP
> Search">/gis/address/cgi-bin/gambitLookup.pl</link>
> <map title="amanda05">
> <file>
> /pearl/SHP/SAINT_PAUL/LIEP/AMANDA/amanda05.map
> </file>
> </map>
> <map title="Address Numbers">
> <file>
> /pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/numbers_only.map
> </file>
> </map>
> <map title="address2">
> <file>
> /pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/address2.map
> </file>
> </map>
> <map title="STAMP">
> <file>
> /pearl/DB/SAINT_PAUL/PUBLIC_WORKS/ADDRESS/STAMP.map
> </file>
> </map>
> </group>
> </mapbook>
