scrolling over a point to view attributes
Steve Lime
steve.lime at DNR.STATE.MN.US
Fri Dec 23 01:15:25 EST 2005
Opps. The correct link is:
http://maps.dnr.state.mn.us/eco/rsg/search/search_example.map
I'll fix the main page when I get to the office. I guess I should move that over to the DNR test suite anyway.
Steve
>>> Larry Shaffer <larry at SHAFFERINTERACTIVE.COM> 12/22/05 4:07 PM >>>
Steve,
The link to the .map file is broken on your example page.
I, too, am interested in image maps and found your example to be helpful.
Larry Shaffer
Black Hills of South Dakota
USA (Mountain Time Zone)
# Steve Lime <steve.lime at DNR.STATE.MN.US> emailed the following
# on Thu, Dec 22, 2005 at 3:19 PM (2:19 PM South Dakota, USA):
>Here's an example:
> http://maps.dnr.state.mn.us/eco/rsg/search/templates/
>We built a little county selection tool using an image map. This uses
>shpxy and repeated calls to
>MapServer to give the effect of selecting counties.
>Steve
>>>> Bob Basques <bob.basques at CI.STPAUL.MN.US> 12/22/05 2:20 PM >>>
>Jennifer,
>I originally put together our first version of this capability for our
>internal developers here at the City.
>This is how I got started, it's not the only way:
>http://www.walterzorn.com/tooltip/tooltip_e.htm
>Once you have a Webpage working with aboveLIB, then the next step is to
>make a TEMPLATE that MapServer can use for Attribute Output from the SHP
>files. to generate Imagemap
>Just read up on:
>http://mapserver.gis.umn.edu/docs/reference/templatereference
>I can't seem to find too much on the Mapserver pages about ImageMap
>generation, (is there something obvious some place that I'm missing?).
>I'm try to find an example of a IMAGEMAP from MapServer Template, but
>not find anything specfically like this.
>Anyone else know of an example that generate straight from the MapServer
>Template (Using SHPXY?)
>bobb
>Jennifer A Bennett wrote:
>>This is a multipart message in MIME format.
>>--=_alternative 00628F4B862570DF_=
>>Content-Type: text/plain; charset="US-ASCII"
>>Thank You for your response Bobb,
>>I was wondering if you could flesh out your answer a little for me; I am
>>still kind of new to mapserver and web design and don't know javascript
>>really well. Do you know of any documentation that could explain the
>>process of creating an IMAGEMAP and displaying necessary attribute fields
>>when scrolling over a point? Can you direct me to your website, so I can
>>see an example of a mapserver imagemap? Do you know of any other websites
>>that use mapserver generated imagemaps?
>>Thanks,
>>Jennifer
>>Content-Type: text/html; charset="US-ASCII"
>><br><font size=2 face="sans-serif">Thank You for your response Bobb,</font>
>><br><font size=2 face="sans-serif">I was wondering if you could flesh out
>>your answer a little for me; I am still kind of new to mapserver
>>and web design and don't know javascript really well. Do you know of any
>>documentation that could explain the process of creating an IMAGEMAP and
>>displaying necessary attribute fields when scrolling over a point? Can
>>you direct me to your website, so I can see an example of a mapserver
>imagemap?
>> Do you know of any other websites that use mapserver generated
>imagemaps?</font>
>><br>
>><br><font size=2 face="sans-serif">Thanks,</font>
>><br><font size=2 face="sans-serif">Jennifer </font>
>>--=_alternative 00628F4B862570DF_=--
