Oracle Woes
Fernando Simon
fsimon at UNIVALI.BR
Fri Dec 23 07:04:36 EST 2005
Hi Christopher,
Just a little more question, did you defined the USING UNIQUE
<column> in your data definition? The query functions/mode only work
when you define a UNIQUE parameter. The <column> must store only
numbers, usually the primary key of the table. You can find more info
about it in the howto.
Best regards.
Fernando Simon
Mapserver and Oracle Spatial Developer
Citando Christopher Condit <condit at sdsc.edu>:
> Hi Fernando-
> I don't think this is a bug. When I looked at the MapServer
> Oracle
> documentation (the site seems to be down now) it only listed WFS
> as
> supported when using OGR to access Oracle. I switched the
> connection to
> OGR and WFS works great. When using the native client, however, I
> don't
> get any information through WFS. This may be more of a feature
> request
> than a bug.
> Thanks for all your help!
> Chris
> -----Original Message-----
> From: Fernando Simon [mailto:fsimon at univali.br]
> Sent: Thursday, December 22, 2005 4:49 PM
> To: Christopher Condit
> Subject: Re: [UMN_MAPSERVER-USERS] Oracle Woes
> Hi Christopher,
> Sorry, I never tested the WFS requests with native connection,
> I
> believe that Bart can answer this question. Bart are you already
> used
> the Oracle native connection with WFS requests?
> I want to recreate your problem here in my computer to find
> the
> bug and fix it. So, can you send me the WFS query that is
> returning
> the wrong result?
> Best regards.
> Fernando Simon
> Citando Christopher Condit <condit at SDSC.EDU>:
> > Hi again-
> > Yes - I hadn't read that document with enough care. Seems to be
> > working
> > now, but I (of course) have one more question - the document
> seems
> > to
> > indicate that Oracle WFS support is only possible using the OGR
> > driver.
> > Is this true? I just get the bounding box when I attempt to get
> > WFS
> > data for my oracle layer.
> > Thanks,
> > Chris
> > Sent: Thursday, December 22, 2005 2:14 PM
> > Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: RE: [UMN_MAPSERVER-USERS] Oracle Woes
> > Hi Christopher,
> > What operations are you triyng to execute? Just draw a map
> with
> > the
> > points? Or any query functions/modes?
> > For native connection the actual extent is used to create the
> > box
> > for the operators, in SDO_FILTER and SDO_RELATE. If you don't
> want
> > to
> > use this operators you just need to specify USING NONE in your
> > data
> > defnition.
> > The link for native connection docs is:
> > http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto
> > Best regards.
> > Fernando Simon
> > Mapserver and Oracle Spatial developer
> > > Hi Fernando
> > > Thanks very much for your response. I added the USING RELATE
> > > operator
> > > and dropped the projection definition from the layer, but
> still
> > no
> > > success. Any thoughts? The database already contained
> lat/lon
> > in
> > > float
> > > columns. I create the spatial column with the following SQL:
> > > alter table SPECIES add (shape mdsys.sdo_geometry);
> > > update SPECIES
> > > set shape =
> > > MDSYS.SDO_GEOMETRY(2001,NULL,MDSYS.SDO_POINT_TYPE(latitude,
> > > longitude,
> > > NULL),NULL,NULL)
> > > where latitude is not null and longitude is not null;
> > > INSERT INTO USER_SDO_GEOM_METADATA
> > > VALUES (
> > > 'SPECIES',
> > > 'SHAPE',
> > > MDSYS.SDO_DIM_ARRAY( -- 1440x720 grid
> > > MDSYS.SDO_DIM_ELEMENT('X', 0, 1440, 0.005),
> > > MDSYS.SDO_DIM_ELEMENT('Y', 0, 720, 0.005)
> > > NULL -- SRID
> > > alter session set sort_area_size = 20000000;
> > > create index shape_idx on SPECIES(shape) indextype is
> > > mdsys.spatial_index;
> > > Thanks,
> > > Chris
> > > From: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > > Behalf Of Fernando Simon
> > > Sent: Thursday, December 22, 2005 12:54 PM
> > > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Hi Christopher,
> > > How you added the data in your database? Using shp2sdo, if
> > > yes,
> > > after the import did you execute the MIGRATE function?
> > > If are you trying to do query functions or modes like
> > nquery,
> > > query, querybyattribute... You need to specify the RELATE
> > operator
> > > in
> > > your data definition, in your case:
> > > DATA "SHAPE FROM (SELECT SHAPE, SCIENTIFICNAME FROM
> SPECIES
> > > WHERE
> > > SCIENTIFICNAME ='Some name') USING RELATE"
> > > Are you already tried to execute the same operations
> without
> > > projection definition?
> > > Best regards
> > > Fernando Simon
> > > > Hi All-
> > > > I'm having tremendous problems getting Oracle 10g Spatial
> > > support
> > > > to
> > > > work with MapServer 4.8 (or 4.6 for that matter).
> > > > I've tried both the native driver and the OGR driver and
> > shp2img
> > > > just
> > > > seems to hang - no error message.
> > > > This table has about 2 million records, with SDO point
> > geometry
> > > and
> > > > a
> > > > spatial index. The query returns about 100 records.
> > > > Am I doing something obviously wrong?
> > > > Ogrinfo does work, however, but I can't find any
> documentation
> > > on
> > > > how to
> > > > add the select statement to an OGR layer in the mapfile.
> Does
> > > > anyone
> > > > have any idea how to accomplish this?
> > > > Any help would be greatly appreciated!
> > > > Here's my layer definition:
> > > > LAYER #Test of Oracle points
> > > > NAME oracletest
> > > > METADATA
> > > > "wfs_title" "SimpleOracleTest" ## REQUIRED
> > > > "wfs_geometry_element_name" "shape"
> > > > "gml_include_items" "all"
> > > > END
> > > > TYPE POINT
> > > > STATUS DEFAULT
> > > > CONNECTIONTYPE oraclespatial
> > > > CONNECTION "user/password"
> > > > # CONNECTIONTYPE ogr
> > > > # CONNECTION "OCI:user/password"
> SPECIES
> > > > WHERE
> > > > SCIENTIFICNAME ='Some name')"
> > > > CLASS
> > > > COLOR 232 0 0
> > > > OUTLINECOLOR 0 255 0
> > > > END
> > > > DUMP TRUE
> > > > PROJECTION
> > > > "init=epsg:4326"
> > > > END
> > > > END #end of layer
> > > > Thanks,
> > > > Chris
> > > Univali - Webmail - http://webmail.univali.br
