Postgis and PostgreSQL Problem
    Frank Fica
    simbiotico at HOTMAIL.COM
    Fri Dec 23 14:35:09 PST 2005
Hi List,
This kind of mistakes are the ones that makes you think what is going wrong  inside my head.
I was checking my map file and realized that I had COLOR 255 255 255 , not the best color to
choose.
Now I can see my map drawn but I still get the messages in my logs.
Frank
>Hi Steve,
>Here is my map definition:
I have also tried DATA "wkb_geometry from ciud_guate_calles"
MAP
  IMAGETYPE PNG
  EXTENT -90.587129 14.541685 -90.433474 14.685685
  SIZE 640 480
  CONFIG CPL_DEBUG "ON"
  SYMBOL
   NAME "circle"
   TYPE ELLIPSE
   POINTS
    1 1
   END
   FILLED TRUE
  END
  LAYER
   NAME "calles"
   TYPE LINE
   STATUS ON
   DEBUG ON
   CONNECTIONTYPE POSTGIS
   CONNECTION "host=xxx.xxx.xxx.xxx port=5432 dbname=xxx user=xxx  password=xxx"
   DATA "wkb_geometry from (SELECT * FROM ciud_guate_calles) as foo using unique ogc_fid using
SRID=32767"
   CLASS
      NAME "calles"
      STYLE
       COLOR 255 255 255
      END
   END
 END
LAYER
    NAME sorento
    TYPE POINT
    SIZEUNITS PIXELS
    TOLERANCE 0
    UNITS METERS
    CONNECTIONTYPE OGR
    CONNECTION "virtual.ovf"
    DATA "sorento"
    STATUS DEFAULT
    DEBUG ON
    CLASS
     NAME sorento
     STYLE
      SYMBOL 'circle'
      SIZE 4
      COLOR 255 0 0
     END
    END
 END
END
>Frank,
>Can you post your layer definition so we can look at that.
>Thanks,
  > -Steve W.
More information about the MapServer-users
