calculating extents with mapscript
Gail Long
codeburg at HOTMAIL.COM
Fri Dec 23 21:07:57 EST 2005
Hi all,
I'm working in phpmapscript and doing a very simple web app that will allow
searches by attribute to return a feature from a shape file (.shp). I have
it so that when querybyattribute is run it returns an exact match for the
attribute string entered in a form and then zooms to the appropriate
location.
I'm getting the correct extents for the feature by using:
$extents = $shape->bounds;
and getting the rectObj.
What I need to know is how to get the bounds or rectangle if there is more
than one attribute returned in the results set because the user entered a
substring or partial match rather than an exact match. I need to handle
both cases.
Any examples would be great!
Thanks in advance.
Things are only difficult while you don't understand them.
