Merge shp file with opensource tool?
luca marletta
lucamarle at GMAIL.COM
Wed Dec 28 05:47:54 EST 2005
Thanks a lot sounds what I need but I built my map file such
LAYER
NAME "edifici"
GROUP "fotogrammetrico"
STATUS ON
DATA "/var/www/lazzate-map/dati/fotogrammetrico/foto_edifici.shp"
TILEITEM "Location"
TYPE POLYGON
#TRANSPARENCY 60
TEMPLATE void
METADATA
"DESCRIPTION" "fotogrammetrico 1:2000"
END
CLASS
NAME "fotogrammetrico"
COLOR 95 95 95
END
END
and the result is the CLASS colors not the POLYGONs inside the the
source shape but the the whole area covered by the source shapes
Where I get wrong?
On 12/28/05, Norman Vine <nhv at cape.com> wrote:
> luca marletta writes:
> > Thanks Bart.
> > Actually I need something that works like gdaltindex for tif.
> > Is it possible to make a shape of shapes like for tif?
> see http://www.gdal.org/ogr/ogrtindex.html
> Norman
luca marletta
