Merge shp file with opensource tool?
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Dec 28 06:01:57 EST 2005
You can use the shptree utility, it comes e.g. with FWTools
(http://www.maptools.org/fwtools).
I would recommend indexing both your source shapefiles and your tileindex
shapefile.
But do check the contents of your tileindex dbf (field LOCATION) to make
sure a) it has absolute paths and b) that the values do not end with .shp
otherwise Mapserver won't find the qix file associated with the shapefile.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: luca marletta [mailto:lucamarle at gmail.com]
Verzonden: woensdag 28 december 2005 11:59
Aan: Eijnden, B. van den (Bart)
CC: MAPSERVER-USERS at lists.umn.edu
Onderwerp: Re: [UMN_MAPSERVER-USERS] Merge shp file with opensource
tool?
Thanks a lot Eijnden,
may I ask which way I can shptree my shapes in such case?
shptree every source shapes or shptree the tileindex shape and
and after just putting the line
TILEINDEX "/var/www/lazzate-map/dati/fotogrammetrico/foto_edifici"
is it?
luca marletta
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
