mapserver error with wms layer [solved]
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Dec 28 09:10:40 EST 2005
Hi Lluís,
don't thank me, thank Daniel Morissette who implemented this feature :-)
Glad to help.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Lluís Garcia i Mestres [mailto:lluisgarcia at tecnics.org]
Verzonden: woensdag 28 december 2005 13:55
Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] mapserver error with wms layer
[solved]
Thanks Bart,
I got it! With the wms_exception_format it works now.
Àrea de Sistemes d'Informació Geogràfica
Tecnics.org - Centre tecnològic i solucions integrals
Plç. Maria Aurèlia Capmany núm.3
Telf. 973 84 46 23
25005 Lleida - Catalunya
----- Original Message -----
From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, December 28, 2005 11:58 AM
Subject: Re: [UMN_MAPSERVER-USERS] mapserver error with wms layer
> Hi,
> Looking at the source code (mapwmslayer.c), using Mapserver 4.8 you should
> be able to use the wms_exceptions_format METADATA at the LAYER level to
> override the exception format that Mapserver WMS client sends.
> So use:
> LAYER
> METADATA
> wms_exceptions_format "application/vnd.ogc.se_xml"
> END
> END
> Hope this helps.
> Best regards,
> Bart
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Xavier Pereta
> Verzonden: woensdag 28 december 2005 11:50
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> I'm having the same problem with that provider, Lluis.
> It seems that Mapserver includes the parameter
> "EXCEPTIONS=application/vnd.ogc.se_inimage" at the end of the request, and
> the provider doesn't like that parameter.
> I have searched the documentation but I haven't found a way to change the
> way Mapserver generates the actual requests to the wms servers.
> I think that a possible solution would be to make the connection to the
> wms
> provider trhough a HTTP proxy. Then you could make the proxy filter out
> the
> "EXCEPTIONS" parameter from the HTTP requests.
> Incidentaly, caching the requests to the wms provider in an HTTP proxy
> seems
> a good idea too, doesn't it?
> Have you found any other solution?
> Greetings,
> Xavier Pereta
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
Disclaimer
