PointObj draw labels
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Wed Feb 2 02:55:20 EST 2005
Hi , try this:
$point = ms_newPointObj();
$point->setXY( $markers_x, $markers_y);
$line = ms_newLineObj();
$line->add( $point);
$shape = ms_newShapeObj( MS_SHAPE_POINT);
$shape->add( $line);
$shape->set( 'text', "this is my label");
$shape->draw( $map, $layer, $image, 0, '');
Kristjan Annus
>I can't seem to be ablt to draw the annotation on the dynamic points added
>using $fPoint->draw($map,$points,$image,$class,"Test");
>I hope I do not need a labelitem, because I am drawing the points on an
>empty point shapefile. Here is the mapfile:
>Thanks,
>Rene.
>$image = $map->draw();
>$class = 0;
>$points = $map->getLayerByName("FLDCHKPTS");
>$points->set("status", MS_ON);
>$fPoint = ms_newPointObj();
>$fPoint->setXY($fDownX[$i],$fDownY[$i]);
>$rtres = $fPoint->draw($map,$points,$image,$class,"Test");
>$fPoint->free();
> LAYER
> NAME "FLDCHKPTS"
> STATUS ON
> TYPE POINT
> MAXSCALE 500000
> DATA "D:/forestry/xtras/empty"
> CLASS
> NAME "Field Check Points"
> STYLE
> SYMBOL 7
> COLOR 0 150 0
> OUTLINECOLOR 0 0 0
> SIZE 10
> MINSIZE 1
> #MAXSIZE 100
> END
> LABEL
> TYPE BITMAP
> SIZE LARGE
> POSITION CR
> COLOR 0 0 0
> END
> END
> END
