small projection problem
Ivan Mjartan
ivan.mjartan at GEOVAP.CZ
Wed Feb 2 04:02:55 EST 2005
Hi David
I was trying your suggestion but my mapserver sed
msLoadMap(): Unknown identifier. Parsing error near (CONFIG):(line 17)
and my map looks like:
MAP
extent -464212.053096 -1109640.531531 -442069.709461 -1093023.599057
imagecolor 255 255 255
size 800 600
UNITS METERS
name "J"
fontset "fontset.txt"
symbolset symbol35.sym
SHAPEPATH "c:\data_gis\index\"
CONFIG "PROJ_LIB" "c:\proj\"
and mapserver verzion is
<!-- MapServer version 4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
I was also trying CONFIG PROJ_LIB "c:\proj\" or CONFIG PROJ_LIB c:\proj\
and it does not work :(
thanks a lot ivan ]
>Ivan,
>In the Map file, you should add a line like this in the MAP object:
>David.
>David J. Fawcett
>MN Office of Environmental Assistance
>>>> Ivan Mjartan <ivan.mjartan at GEOVAP.CZ> 2/1/2005 9:09:12 AM >>>
>Hi I have small problem with file epsg, because it's location in my
>project (I am running on W2K and IIS) have to be
>c:\proj\nad\epsg
>Know somebody where can i redefine location of epsg file? I thing that
>i have to make some change in code of mapserver but i dont known where.
>thanks for your reply.
>ivan mjartan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050202/880b7e0e/attachment.html
