mapserver4.4.1 binary build
Bob Bruce
covariance at SHAW.CA
Wed Feb 2 11:11:06 EST 2005
John:
the "MapServer 4.4 Win32 Compilation and Installation HOWTO" at
http://mapserver.gis.umn.edu/doc44/win32_compile-howto.html explains that
you will likely have to fix this in regex.c, after fixing it your code
should look like:
//extern void printchar ();
void printchar( int i ) {}
instead of:
I suggest you open the HOWTO and search for "printchar"
I'm in the middle of trying to sort out problems with the WIN32 build myself
and came across this.
Bob Bruce
On Tue, 1 Feb 2005 12:19:37 +0200, John Spotten
<John.Spotten at CAPETOWN.GOV.ZA> wrote:
>Hi All,
>tried to use binary mapserver with sde support for windows from
http://hobu.stat.iastate.edu/mapserver/ but it requires sde90.dll.
>I only have sde83.dll so I tried to build the basic mapserver using
mapserver4.4.1.tar.gz with no changes to nmake.opt file to start of with.
>required pre-built gd2.0.33 files in c:\projects\gdwin32\ and regex-0.12
files in c:\projects\regex-0.12\ and mapserver base directory is
c:\projects\mapserver.
>all obj files including regex.obj, mapserver_i.lib, mapserver_i.exp and
mapserver.lib were created but in the linking the following was produced
> Creating library mapserver_i.lib and object mapserver_i.exp
>regex.obj : error LNK2001: unresolved external symbol _printchar
>libmap.dll : fatal error LNK1120: 1 unresolved externals
>NMAKE : fatal error U1077: 'link' : return code '0x460'
>Stop.
>any clues. is regex.obj compatible with mapserver 4.4.1
>bye
>john
>John Spotten
>Transport Modeller/GIS Developer
>Directorate of Transport, Roads and Stormwater
>City of Cape Town
>Tel : +27 21 4067325
>Fax : +27 21 4186989
>Cell : +27 846678901
>Email : john.spotten at capetown.gov.za
>Web : www.capetown.gov.za
> <<John Spotten.vcf>>
>QkVHSU46VkNBUkQNClZFUlNJT046Mi4xDQpOOlNwb3R0ZW47Sm9obg0KRk46Sm9obiBTcG90dGVu
>DQpPUkc6Q2l0eSBPZiBDYXBlIFRvd247TUVUTElGRSBCVUlMRElORw0KVElUTEU6RW5nL1BsYW5u
>ZXINClRFTDtXT1JLO1ZPSUNFOjQxOC02ODMwDQpFTUFJTDtQUkVGO0lOVEVSTkVUOkpvaG4uU3Bv
>dHRlbkBjYXBldG93bi5nb3YuemENClJFVjoyMDA0MTAyOFQwNDU5MDZaDQpFTkQ6VkNBUkQNCg==
>NOTE: This e-mail (including attachments) is subject to the restrictions,
qualifications
> and disclaimers (âdisclaimerâ) published at
www.capetown.gov.za/disclaimer/email.pdf.
>Please read the disclaimer before opening any attachment or taking any
other action in
>terms of this e-mail. If you cannot access the disclaimer, kindly send an
email to
>infomail at capetown.gov.za and a copy will be provided to you. By acting on
this e-mail
>or opening any attachment you agree to be bound by the provisions of the
disclaimer.
