Draw circle
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Feb 2 17:49:51 EST 2005
It is mentioned in the mapfile-reference doc, but i've created a bug to
add Steve's example to the doc
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1205).
jeff
Stephen Woodbridge wrote:
> This sounds cool, is it in the documentation?
> Steve Lime wrote:
>> There is also a CIRCLE layer type. You can construct a shapefile of
>> simple lines, 2 points per line. Where the points represent the bounding
>> box for the circle (this works with inline features too). The LAYER
>> might look like:
>> LAYER
>> NAME 'circles'
>> TYPE CIRCLE
>> DATA '/usr/local/data/circles'
>> END
>> Steve
>>>>> Jeff Portwine <jdport at VERITIME.COM> 2/2/2005 10:24:37 AM >>>
>> Put something like this in your map file. The numbers in the
>> "points" section refer to the diameter in the X direction and the
>> diameter in the Y direction. If the numbers are the same you get a
>> circle, otherwise you will get an ellipse.
>> SYMBOL
>> NAME "circle"
>> TYPE ellipse
>> FILLED true
>> POINTS
>> 12 12
>> END
>> END
>> -Jeff
>> ----- Original Message -----
>> From: Jose Luis Gonzalez
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Sent: Wednesday, February 02, 2005 11:02 AM
>> Subject: [UMN_MAPSERVER-USERS] Draw circle
>> Is there any easy way to draw a circle on a map without having to
>> make it your self by drawing small lines?
>> thank you
>> Jose Luis
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
